need help from sohc build up guys
this question is to all of the peeps that have built sohc's
im getting a 91civic hb dx and My friend told me for decent power untill i can afford a swap i should do this and i ask you if it would be worth the money and would it be good
he says
stock block
d16z6 head (vtec)
si cam (higher lift)
si tranny (better gears)
and i dont know jack about engines and **** so any help would be great
[Modified by needahatch, 6:14 PM 11/28/2002]
he says
stock block
d16z6 head (vtec)
IMO, just stick with your stock motor and save your money until you can afford a B-series motor. You'll be spending at least $300-$500 for what you want to do, if you saved that, you'll be that much closer to a B16 or B18. BTW, a Si cam won't work in the Z6 head.
Well I'm putting a mini-me in my 88 hatch, but only because I got the Z6 head and D15 bottom for free. I just had to get new gaskets and such. If I had to start from scratch, then I'd save for a B-series motor. Don't get me wrong, I think D-series engines are highly underrated. BTW, I assumed he meant an 88-91 Si cam.
Wes90civic
Jan 6, 2004 03:14 PM
1CiViC1
Aug 1, 2003 11:32 AM
USDMMARK
Dec 26, 2002 03:01 AM
