will a camber kit help?
Old Nov 28, 2002 | 02:10 PM
d8168055's Avatar
Default will a camber kit help?
1. i got into an accident when my car was lowered.
2. my car was fixed to factory specs (and camber).
3. i put my car up to stock height...
now one of my wheel is positive cambering too much... will a camber kit help to add some negative camber? if so what brand? thanks...
Old Nov 29, 2002 | 08:28 AM
Reid's Avatar
Global Moderator
Default Re: will a camber kit help? (d8168055)
Get an alignment.
If any suspension arms are bent, replace them.
Old Nov 29, 2002 | 08:37 AM
hungsteR's Avatar
After the car was lowered how was the camber fixed back to factory specs? By a Camber kit or by which method?
sivik2nr's Avatar
Default Re: will a camber kit help? (Reid)
Get an alignment.
Old Nov 29, 2002 | 08:41 AM
tjtruong's Avatar
New User
Default Re: will a camber kit help? (sivik2nr)
it can be many things that make your one wheel to have a positive camber.. Go to alignment shop and see what they say and if it is indeed positive camber in one wheel, you have something bent. Especially if your car is lowered. Being lowered would assume you would have negative camber. You might have bent a control arm or if it is in the front it could be the Knuckle or the control arm.. Alignment shops will tell you for sure though.
Tj
khronicboy420
Dec 23, 2008 11:12 AM
th34nt0ni0
Suspension & Brakes
Dec 21, 2008 02:15 PM
BJA86
11
Sep 2, 2007 01:00 PM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
Kyles ej1
26
Nov 19, 2004 06:09 AM
