still having trouble with hesitation at high rpm
Old Nov 28, 2002 | 12:51 PM
andrewasf77's Avatar
Default still having trouble with hesitation at high rpm
my 97 itr is having a hesitation at around 7k rpm. im still not sure whats going on, i pulled the vtec solenoid and cleaned the screen, i checked the plugs-they are burning ok, i just dont know what is going on. i had some valves replaced a while back because of a mishift, but the motor is bone stock, anyone have any ideas? i was thinking maybe it was ignition or electrical since it doesnt do it all the time. maybe plug wires, rotor, coil? i just dont know, i am throwing cel code 67, which is the cat, dont know if that effects anything or not, but i dont think so. any help is appreciated, thanks
btw Happy Thanksgiving
Old Nov 28, 2002 | 12:54 PM
Dave-ROR's Avatar
Default Re: still having trouble with hesitation at high rpm (andrewasf77)
Andrew: I thought you were going to replace the rotor, cap, plugs and optionally the wires per the other thread you created regarding this issue?
Old Nov 28, 2002 | 01:01 PM
Default Re: still having trouble with hesitation at high rpm (Dave-ROR)
well dave i was untill someone here told me that wasnt really necessary, he told me to check my vtec solenoid, remove it and clean the filter, was that a waste of time?
[Modified by andrewasf77, 5:02 PM 11/28/2002]
Old Nov 28, 2002 | 01:23 PM
Misfit's Avatar
you have enough oil in your car? when mine is low it does that. just a thought.
Old Nov 28, 2002 | 01:30 PM
Chubz's Avatar
Default Re: still having trouble with hesitation at high rpm (MISFIT)
its ignition related
ITR764's Avatar
what plugs do you have and when was the last time you changed them??
Old Nov 28, 2002 | 01:40 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I had the same problem. It was the distributor coils.
Old Nov 28, 2002 | 03:21 PM
Default Re: still having trouble with hesitation at high rpm (ActiveAero)
i have the stock ngk plugs, not sure the last time i changed them, probably due for that too. since the motor is bone stock, i should just go with the stock plug wires right, oem coil, cap, can rotor also, right?
Old Nov 28, 2002 | 03:27 PM
Bbasso's Avatar
Start with the stuff you should have done and then look for any problems, most likely you won't have any if you maintain your car correctly
Can't remember when you changed plugs last Maybe you should have a journal of whats done to your car. and not guess when its time to change items...
Old Nov 28, 2002 | 03:29 PM
ITR764's Avatar
Default Re: still having trouble with hesitation at high rpm (Bbasso)
good idea!! i can't remeber ish so i have to write things down...
Old Nov 28, 2002 | 04:34 PM
Dave-ROR's Avatar
the vtec sole was worht a try, but you have over 60k miles right? I wouldn't use stock rotor, cap, wires and plugs for over 60kish, but I think Acura claims more than that. Either way, hesitation is generally ignition or fuel related so replace the parts that should be replaced anyways makes sense IMO.
Old Nov 28, 2002 | 04:36 PM
i agree, that is poor on my part, no arguement from me, the journal is a good idea, and i will do it, thanks for the tip. but as for as the current problem goes, oem everything since the engine is bone stock? or are the better performing after market products available that i might want to look into?
Old Nov 28, 2002 | 04:37 PM
Dave-ROR's Avatar
OEM Cap
OEM Rotor
OEM Wires
NGK Platinum or Copper plugs (copper requires more frequent replacement, but is cheaper).
Old Nov 28, 2002 | 04:38 PM
ive only got 53k miles on it. as far as ignition replacement have i covered everything with the rotor, cap, coil, plugs and wires? what aftermarket should i go with if im not using oem? and what about fuel related, what should i look at there?
Old Nov 28, 2002 | 04:43 PM
Dave-ROR's Avatar
It's far more likely to be ignition IMO. Just replace those with the parts in the post above yours and see if that fixes it
Old Nov 28, 2002 | 04:46 PM
i should have done that yesterday when i was messing with the solenoid, oh well, i dont have another day off untill sunday, so ill probably do it then. what about the coil? ill let you know what happened and if the problem is fixed. anything i should look for when taking off the old parts that would be a tell tale sign? thanks
[Modified by andrewasf77, 8:46 PM 11/28/2002]
Old Nov 28, 2002 | 05:00 PM
xjohnx's Avatar
Old Nov 28, 2002 | 07:35 PM
Default Re: still having trouble with hesitation at high rpm (xjohnx)
the oil was the first thing i checked. vtec is highly dependant on oil, but thanks for the suggestion
Old Dec 4, 2002 | 07:44 PM
hey dave, i did it today and i still getting my hesitation, and still getting code 67. what next. maybe taking off the cat and replacing the secondary o2 sensor? could code 67 cause the hesitation?
Old Dec 4, 2002 | 07:45 PM
Dave-ROR's Avatar
67 wont cause anything, just come to the next florida meet and the we-todd's will fit in a diagnostic time. next one is in orlando in jan.
Old Dec 4, 2002 | 10:18 PM
thanks dave, keep me up to date on the date, time and location. so removing the cat and checkiing for cloggs and replacing the sensor is a waste of time?
Old Dec 4, 2002 | 10:23 PM
ill definately be there, not just to try find out whats wrong with the car, but to hang out with the we-todd's
stretchd1
Mar 11, 2011 05:50 PM
Peeonu25
Jan 26, 2009 04:24 PM
young-richie
Aug 23, 2007 06:57 PM
ejmatzell
Jun 10, 2006 04:08 PM
andrewasf77
Nov 29, 2002 07:53 AM
