What Camber kit do you guys use?
Old Nov 28, 2002 | 11:17 AM
DC2ITR's Avatar
Default What Camber kit do you guys use?
Almost every other H-T member has their R lowered.
Let us know if you do or do not use a camber kit. If you do use a camber kit, what kind??
Please post some pictures if you got it.
Old Nov 28, 2002 | 11:22 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What Camber kit do you guys use? (DC2ITR)
Stock suspension rules me!
Rguy, one of the "other" non-lowered R's.
Old Nov 28, 2002 | 11:33 AM
Rory Breaker's Avatar
About a ~2" drop, no camber kit. Just monitor the wear and rotate frequently and Im a-ok, for now. Been about a year and 20k+ and Im doing alright.
Old Nov 28, 2002 | 11:58 AM
EleanoR's Avatar
Default Re: What Camber kit do you guys use? (newgsrdriver)
Skunk2 with better bolts/ self locking nuts. It isn't going to slip no matter what. I guarantee it. Nice piece. I like it so far. I run -1.8 on the street.
Mike
Old Nov 28, 2002 | 12:55 PM
Ricky Rojales's Avatar
Sprint +/-3 up front, +/-2 Ingalls in the rear.
Old Nov 28, 2002 | 01:24 PM
RiCE On IcE 2's Avatar
Default Re: What Camber kit do you guys use? (P)
if u have a pilloe bar uppermount can some of those actually control camber? does it do a good job I dunno much about the uppermounts... but I might get the option on zeal B2's cus it cost a little less then getting a seperate camber kit I think.
Old Nov 28, 2002 | 10:28 PM
DC2ITR's Avatar
Default Re: What Camber kit do you guys use? (George Knighton)
Old Nov 28, 2002 | 10:32 PM
TKBLAZER's Avatar
i am using the ingalls kit...works ok i guess, install was straight forward. remember to get your car aligned right after the install tho
Old Nov 28, 2002 | 11:18 PM
Phoenix_ITR's Avatar
I find that the special Jacobs-designed PVC Spoon Spacers work wonders for adjusting camber.
would you mind giving a little more information about how this works?
-tony
Old Nov 29, 2002 | 05:42 AM
DutchITR1689's Avatar
BTW Does lowering the car change the toe too? Maybe the rear toe?
Old Nov 29, 2002 | 06:06 AM
PM-Performance's Avatar
SPC;s on all my cars . even the race cars
Old Nov 29, 2002 | 06:10 AM
EleanoR's Avatar
Default Re: What Camber kit do you guys use? (itr206)
George~
Have you got the new suspension setup installed yet?
Old Nov 29, 2002 | 06:19 AM
Doctor CorteZ's Avatar
He is still putting the Evo2's in
nice...
Old Nov 29, 2002 | 06:23 AM
4-1-1's Avatar
Default Re: What Camber kit do you guys use? (Doctor CorteZ)
Ingall
Old Nov 30, 2002 | 09:42 PM
Default Re: What Camber kit do you guys use? (4-1-1)
some pillowball mounts can control camber though correct?
Old Nov 30, 2002 | 10:35 PM
DC2-8888's Avatar
i used ingal b4, but i think SRR is better and cheaper, my friend use cuzco it comes with ball joint is much nicer and too much $$$
Old Nov 30, 2002 | 11:53 PM
MK Ultra's Avatar
Default Re: What Camber kit do you guys use? (scmdl26)
No, pillow ball upper mounts can only adjust camber on a MacPherson strut type suspension.
With a Mac strut suspension a change in the inclination of the strut can change camber. With double wishbone suspension (as found on the Integra) inclination of the shock body has nothing to do with camber. Camber is defined with a double wishbone suspension by the geometry of the control arms.
In my case I have chosen to have the knuckles slightly bent in a press to change the relationship between the upper and lower control arms, thus changing camber. It is not adjustable, and not for everyone, but it is the route I selected.
Old Dec 1, 2002 | 02:07 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: What Camber kit do you guys use? (EleanoR)
Mike
Old Dec 1, 2002 | 04:17 AM
TurboR1391's Avatar
Default Re: What Camber kit do you guys use? (dLo GSR)
On my previous Hondas I used Ingalls!
Old Dec 1, 2002 | 07:11 AM
ITR21's Avatar
Default Re: What Camber kit do you guys use? (TurboR1391)
SPC
Old Dec 1, 2002 | 11:23 AM
primoEF's Avatar
Default Re: What Camber kit do you guys use? (ITR21)
skunk2 for the front and some washers for the rear, you might need ingall if you are looking more camber for the rears
LOC714
Sep 17, 2007 04:47 PM
JRTegman987
Suspension & Brakes
Oct 22, 2006 11:38 PM
lsvtec_DA
Feb 25, 2004 09:59 PM
stspj
May 28, 2002 07:21 PM
