Coolant leaking from left side of head gasket
Coolant is leaking from the left side infront of the distributor. Compression is ok 240psi. Oil is not mixing with coolant. It leaks out little at low rpms but when the rpms rise more coolant sprays out. What is the problem, any suggestions?
im not sure if its the same problem but i noticed something similar in my sunfire right before the head gasket went kablooey. At first my compression was fine, but as the problem got worse so did compression so watch that real close. is it hurting the performance? missing, idling rough, or knocking?
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
