Can someone help me "Spade" maybe you can help me out
Old Nov 28, 2002 | 12:56 AM
pwrdbydzntz's Avatar
Default Can someone help me "Spade" maybe you can help me out
Well my car '97 HX D16Y5' is still running like **** so I replaced the 5 wire o2 sensor that didn't fix my problem so I replaced the plugs and the wires the ignition coil, rotor,cap and it still missfires throughout the entire rpm range and no codes i've had diagnostics done and they said that it lopes and retards the timing because its running rich then lean and back and forth but we couldnt figure out wtf is wrong
this all happened after i installed a EX headder on my car
Anyone know what else it could be ?
Old Nov 28, 2002 | 05:43 AM
DragII's Avatar
25 Year Member
Default Re: Can someone help me "Spade" maybe you can help me out (pwrdbydzntz)
check fuel pressure, fuel pump, and injectors.
Old Nov 28, 2002 | 06:49 AM
Eee Pee's Avatar
Default Re: Can someone help me "Spade" maybe you can help me out (Tetsuo)
with a multimeter, get resistance readings...everywhere!
Old Dec 2, 2002 | 12:20 AM
Default Re: Can someone help me "Spade" maybe you can help me out (E Prep)
What resistance should they be at? What should I have the multimeter set at i know Ohms but which one kilo ohms and what should i be comparing them to like a haynes manual or what?
BoostdRex
Nov 24, 2006 03:24 PM
La EF-8
Jul 30, 2006 06:09 PM
CircuitFG
May 18, 2006 06:55 PM
d_mina
Jan 6, 2004 10:27 AM
Dutchie
May 7, 2002 11:50 PM
