How to remove winder winders on EK?
first roll the winder till the **** points down/south/to the ground. then put pressure on the door panel pushing it away from the winder...take a peek and you will see a plastic cover(more like a cover plate) take a needle nose pliers or a flat head screwdriver and separate the cover plate from the winder and you will see a lockpin...now take a hook(diy: hook from a coathanger or paperclip) and hook that lockpin and pull up...voila, your worries are over...good luck and have turkey on me.
bori bori
Nov 29, 2009 08:34 AM
98vsmferio
May 7, 2005 12:04 PM
1 speedstar
Mar 31, 2003 04:34 PM
