Clutch pedal falls to the ground...
Old Nov 27, 2002 | 11:43 PM
migs's Avatar
Default Clutch pedal falls to the ground...
I just got done doing a 3hr road trip. I was on the highway at cruising speeds and my clutch pedal decides to drop 50% of the way down.
The EXTRA 50% engages the clutch like it was normal, but sitting lower? I had to pull the pedal back up with my toe to fix it and now its normal? I do notice my clutch reservoir is a LITTLE low but not below the minimum mark.
What are the possibilities my slave cylinder might be out?
BTW, I have an Exedy Organic Street clutch combo.
Happy Thanksgiving,
migs
Old Nov 27, 2002 | 11:57 PM
civura R's Avatar
Default Re: Clutch pedal falls to the ground... (Migs)
try and bleeding it u might have a bubble
Old Nov 28, 2002 | 12:38 AM
NWPNOMORE's Avatar
Banned
happened to me before, i thought my clutch was bad at first. I bled it and it worked fine ever since.
Old Nov 28, 2002 | 06:19 AM
Batoutahell's Avatar
Yep, sounds like you have air in your line. You can gravity-bleed the clutch pretty effectively, and you don't even need a friend to help.
Old Nov 28, 2002 | 07:20 AM
ronpopiel's Avatar
Same thing happened to me, my mc took a dump on me. You can bleed it but it's not going to fix the problem and probably dangerous driving around like that. Don't just bleed it, check your mc and slave cylinder, sh$t like this happen for a reason. It's not like a frickin bubble fairy flying around making air bubbles appear in your clutch lines.
Old Nov 28, 2002 | 07:22 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: Clutch pedal falls to the ground... (ronpopiel)
may be a ghost....
Stonage07
Mar 6, 2017 11:48 AM
LOC714
Sep 23, 2004 12:34 PM
kupras
Nov 27, 2003 09:54 PM
Paste
Aug 15, 2002 08:49 PM
gsr camel
Sep 13, 2001 12:05 PM
