People with OE civic foglights on 92-95's....
Old Nov 27, 2002 | 09:18 PM
SpoonFedHatch's Avatar
Default People with OE civic foglights on 92-95's....
i am looking into purchasing/installing a set.....the wiring shouldnt be a problem, my only concern is.....what all must be cut out to fit the plate in.....also, did you have any difficulty getting the setup to slide in perfectly/aim correctly??? thanks in advance
Old Nov 27, 2002 | 10:40 PM
markpaco's Avatar
Default Re: People with OE civic foglights on 92-95's.... (SpoonFedHatch)
installation instructions
Old Nov 27, 2002 | 11:36 PM
lucas569's Avatar
Default Re: People with OE civic foglights on 92-95's.... (markpaco)
anyone know how to wire it up so they dont turn off w/ the highbeams on or how to put em on w /the low beams off?
Old Nov 27, 2002 | 11:56 PM
VTEC
Guest
Posts: n/a
Default Re: People with OE civic foglights on 92-95's.... (lucas569)
Buy OEM-style if you want the fogs to stay on all the time...it's cheaper too!
Old Nov 28, 2002 | 04:47 AM
VTECVillain's Avatar
By using a relay found at Radio Shack and some wiring you could have them on but when you change to highbeams it will cut them out or vice versa.
Old Nov 28, 2002 | 07:49 AM
Default Re: People with OE civic foglights on 92-95's.... (VTECVillain)
thanks for replies, 'preciate it
Old Nov 28, 2002 | 04:45 PM
CXHatchback's Avatar
What I did was wire them into an extra spot in the fuse block underneath the dash. They don't go off with the highbeams, but must have the parking lights on to work.
Old Nov 28, 2002 | 05:07 PM
Bigjon
Guest
Posts: n/a
Default Re: People with OE civic foglights on 92-95's.... (CXHatchback)
Useing a relay and whatever switch you want you can wire it so that it can come on and go off whenver the f you want it to.
Old Nov 29, 2002 | 12:05 PM
skunkwhat's Avatar
Default Re: People with OE civic foglights on 92-95's.... (Bigjon)
using extra position #3 on the fuse box will alow you to have power to the switch anytime the car is the on or run position.
So if you have the factory wiring just run the input side of the 15A fuse holder(the bigger red wire) to the #3 spot on the fuse box.
This way you can keep the fogs on all the time and have them shut off automatically with the car, and they dont shut off with the highs on.
Old Nov 29, 2002 | 04:07 PM
lucas569's Avatar
Default Re: People with OE civic foglights on 92-95's.... (skunkwhat)
great info!
Old Nov 29, 2002 | 04:10 PM
oldB18EF's Avatar
mine are wired this way and I was told by my inspector that this will cause you to fail inspection here in PA...he passed me anyway because I know him but just some info for you
gjohns
Honda Fit
Aug 26, 2016 11:10 PM
goldsy
Honda CR-V & Element
Jan 7, 2014 09:26 AM
hondatuningboi96
May 4, 2008 07:03 AM
Sean EH2
Mar 26, 2007 07:42 AM
turboman
Jan 25, 2006 04:04 AM
