ticking noise
Old Nov 27, 2002 | 09:10 PM
rasta420's Avatar
Default ticking noise
when the throttle is opened, i hear a loud ticking noise from the engine...at idle its fine.
as the throttle is opened wider, the ticking gets louder...could it be the valves hitting?
Old Nov 28, 2002 | 06:08 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: ticking noise (rasta420)
Rods!
Old Nov 28, 2002 | 07:49 AM
TODAwhore's Avatar
Default Re: ticking noise (h8tred)
check your valve lash.. if its a rod you're more likely going to hear it at idle also.
[Modified by TODAwhore, 11:51 AM 11/28/2002]
Old Nov 28, 2002 | 08:12 AM
PaImportTuner's Avatar
Default Re: ticking noise (TODAwhore)
"check your valve lash.. if its a rod you're more likely going to hear it at idle also."
I second that... cause it will start clacking then at IDLE and getting louder and louder while accelerating.. IF it was rods.
Old Nov 28, 2002 | 03:48 PM
rasta420's Avatar
Default Re: ticking noise (PaImportTuner)
how would i check "valve lash?"
Old Nov 28, 2002 | 05:08 PM
CRX Si's Avatar
you gotta pull the valve cover off and get out your fealer guages...
Old Nov 28, 2002 | 08:12 PM
civbeater90's Avatar
Default Re: ticking noise (CRX Si)
yeah check those clearances
Old Nov 29, 2002 | 03:23 PM
90da's Avatar
If you don't know what it is then I would suggest getting a professional or someone who knows how to do it take a look. It is kinda hard to set them properly if you haven't done it before. Any Haynes manual will have the proper clearences or someone on here will know them.
RHCivic
Honda Civic (2001 - 2005)
Jun 21, 2018 08:35 PM
AnAccordIsForever
Jul 13, 2006 11:52 AM
jmv38
Apr 10, 2006 01:05 PM
4gen
Dec 7, 2003 09:35 AM
onyx00
Apr 30, 2003 05:51 AM
