HX intake manifold
Old Nov 27, 2002 | 05:31 PM
civicmatt's Avatar
Default HX intake manifold
What are the differences between the hx and ex intake manifolds for the same year? Are there any differences? Thanks.
Old Nov 27, 2002 | 06:20 PM
eg6ajk's Avatar
Default Re: HX intake manifold (civicmatt)
EGR system vs non EGR on the EX
Old Nov 28, 2002 | 10:52 AM
civicmatt's Avatar
Default Re: HX intake manifold (eg6ajk)
Can that be adapted to work on a dx motor? Other than that, are they the same?
Old Nov 28, 2002 | 03:36 PM
Kataku2K3's Avatar
I'm not sure about the HX.... A few years ago I wanted to but an EX manifold on my friend's 99 DX motor... Now that i think about it i really don't know how i would have done it... For the most part i don't work with SOHC motors but i do know that you will have a few problems... The DX manifold uses a 3 pin rotary style IAC and just about every other manifold B/D series all use the 2 pin linear IACs... It is possible to rewire for this manifold but you'll need a ECU that is set up for the linear style IACs... If you want something simple i would just swap a VTEC head and tranny on your motor... If you just want a little extra power then drop a B16... Personally I would go with a B18C but they are a little more spendy... Good luck...
civicguy1984
10
Dec 7, 2006 02:07 PM
bibong
10
Oct 11, 2006 05:53 AM
98HondaCivicDX
Sep 15, 2004 05:06 AM
monicle
Jun 21, 2004 05:25 AM
