a/f gauge install
i have a 92 cx...i tried to search for what wire is connected to the o2 sensor but can't find it...just wondering what color the wire is that goes from the ecu to the o2 sensor...thanx...
drew
drew
thanx for the help...i tried pin d14 and it did all kinds of whacky stuff when u put on the lights, blinkers, heater, etc...what connector is the all white wire in on the ecu...a,b, or d? i thought i would be able to find a wiring diagram easy...o well time to uy a manual...peace
drew
drew
sorry for late reply um the wire is red/white
[Modified by couter, 2:58 PM 11/28/2002]
I just installed my gauge in my dash, only took about 1 hour, and it fit really tight. I am running the wires behind my glove conpartment, but I still am a little stumped, it was a lot easier on my prelude.
What 5 amp fuse should I put my power wire to?
I cannot find the wiring harness that looks like the picture above, where is it located on a 92 hatch?
TIA
TIA
very helpful of you above
the wiring diagram above is that of your ecu, which is burried in the corner of the passenger side kick panel. Tap the wire to d14 as suggested above.
-Bryan-
the wiring diagram above is that of your ecu, which is burried in the corner of the passenger side kick panel. Tap the wire to d14 as suggested above. -Bryan-
thanx for the help guys...i figured out what i messed up...in my haste late at nite i just counted wires from the end and not the actual pin openings...so i was in like d 12 or somethin...but now it's fine...thanx again for the help...peace
drew
drew
93ludeSi
Nov 15, 2003 08:02 PM
Kermit EK
Feb 28, 2003 07:07 AM
