Integra LCA's on my civic?
Old Nov 27, 2002 | 02:11 PM
Stop the Beast's Avatar
Default Integra LCA's on my civic?
Will it work properly if I put 91' Teg Rear LCA'a on my 91' STD Civic? I ask because I want to use them with the 91' teg sway bar (sedan) I have.
Old Nov 27, 2002 | 03:48 PM
bryant's Avatar
Default Re: Integra LCA's on my civic? (FFgeokstar)
bolt it up and find out. It should work though
Old Nov 27, 2002 | 09:45 PM
zCivic's Avatar
Default Re: Integra LCA's on my civic? (CR-X)
It works, have used them on 2 of my own civics and put a set on a friend DX. Used them because a hella lot easier to find the Civic/Crx Si.
Old Nov 28, 2002 | 07:01 AM
4potnick's Avatar
Default Re: Integra LCA's on my civic? (zCivic)
Is there any benifit of using the teg sway bar on 4g civic?
Old Nov 28, 2002 | 08:17 AM
Overkll's Avatar
The integra LCA's have a slightly different geometry than the stock LCA's (still work though). They increase the rear track by about 1/4" on each side (not sure if that's exact-it is noticeably further out). Be prepared to do some fender rolling if you're lowered and on 205 width rubber.
Later, Overkll
Old Nov 28, 2002 | 09:07 AM
4potnick's Avatar
Default Re: Integra LCA's on my civic? (Overkll)
does anyone else have any experiences with rubbing with these i have some nuespeed race springs and 16in rota c8's. Am i going to have probs when i put the teg rear lca's in?
Old Nov 28, 2002 | 10:50 AM
pdog's Avatar
91 hatch 4 sale. white dx. $700.00 let me know tell any one u know that might want it. pdog37@hotmail.com
Old Nov 28, 2002 | 05:14 PM
I bolted up the LCA's and it seemed to handle the same but did look as if the camber and/or toe in was off. Any way I think I'll use them. Any ideas on how to mount the sway bar to the body?
Old Nov 29, 2002 | 05:36 PM
Ham'ed Hatch
Guest
Posts: n/a
there should be two threaded holes (some say there's holes there, but no threaded. but mine were threaded.) in front of the tow hooks on each side. you'll need civic/crx Si brackets that'll bolt to the body using those holes. the integra bushings on the bar will bolt to the Si brackets. integra brackets don't have the same bolt pattern though and will not work.
that's how my car is at least...
Old Nov 30, 2002 | 12:53 PM
Default Re: Integra LCA's on my civic? (Ham'ed Hatch)
I'll have to check for the other set of threaded holes before I tap and weld it then...
Old Dec 1, 2002 | 01:31 PM
4potnick's Avatar
any advantage of using teg rear sway bar?
Old Dec 1, 2002 | 07:26 PM
Default Re: Integra LCA's on my civic? (4potnick)
As opposed to no sway bar at all, definetly. As for the size I'm sure that the 'Teg Sedan sway bar is atleast 15mm so thats better than an Si.
Old Dec 7, 2002 | 04:29 PM
Got the mounts and swaybar installed. The oe holes must be for Si brackets because they didn't line up with the 'Teg mounts (well one oe hole did). So holes were tapped and the brackets were bolted on then because of lack of material I had the brackets welded around the outside. Works great!
Old Dec 7, 2002 | 10:57 PM
Ham'ed Hatch
Guest
Posts: n/a
gee...glad i could be of help.
R.I.F. dude.
edit: fixed all my quoting.
[Modified by Ham'ed Hatch, 1:03 AM 12/8/2002]
Old Dec 8, 2002 | 09:29 AM
Yeh you were I expected them not to fit because of you. So before I started the install I went out and grabbed a drill and tap.
Old Jul 26, 2004 | 01:30 PM
bdb's Avatar
bdb
Anyone know if 94+ Integra rear LCA's work on my '90 Civic HB? Do they bolt up?
Old Jul 26, 2004 | 02:00 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeokstar &raquo;</TD></TR><TR><TD CLASS="quote"> Any way I think I'll use them. Any ideas on how to mount the sway bar to the body?</TD></TR></TABLE>
I just finished putting a CRX stock sway on my sedan.
I had NO HOLES at all! Not even unthreaded ones!
I mounted the sway to the LCA's (ITR LCA's) and then flipped the brackets up to the frame rails.
I marked the holes appropriately and then drilled them.
Then, I pressed on and drilled up through the floor of the trunk.
I bought a hole saw drill bit thing (look like a cylinder with saw teeth on the end) and made a 1-1/16" hole at each spot the drill poked into the trunk.
I put some big washers on and bolted it to the frome rail.
The 1-1/16" hole lets a standard socket fit right in there for tightening the bolt in place.
I'll be buying some big grommets to fill the holes.
It's all covered by carpet so I won't ever see it!!!
racingant
Apr 23, 2006 08:54 PM
importboi22
12
Mar 8, 2004 04:14 AM
SiZ
Oct 25, 2003 11:05 AM
Kyo Babic
Mar 9, 2003 09:08 AM
b16awarrior
Jan 23, 2003 09:54 AM
