Suspension Problems. Please help!
Old Nov 27, 2002 | 01:47 PM
poo flinger
Guest
Posts: n/a
Default Suspension Problems. Please help!
Hey guys,
I was driving around and I hit something in the road. This jolted my car pretty good. It punctured my rear drivers tire on the outer part. I thought everything was fine but when I drove it around. The alignment was all tweeked. And the rear driver side felt like it was swaying when I turned the wheel. When you look at that back tire, the bottom of the wheel sticks out really bad, and the upper part of the wheel is stucked under the fender well. It has really bad camber. I checked the shock but I did not see anything leaking. Could the shock still be blown? Now, I don't know to much about suspension but my current setup is Skunk2 coilovers, Tokico Blues, and a 22mm Skunk2 sway bar. If ANY of you guys can give me an idea on what to look for or replace, I would greatly appreciate it. THANKS!
Old Nov 27, 2002 | 02:10 PM
976's Avatar
976
New User
Default Re: Suspension Problems. Please help! (I cant believe this ****)
Just get alignment, it'll fix your camber which got dealigned during inncident.
Old Nov 27, 2002 | 02:16 PM
poo flinger
Guest
Posts: n/a
Default Re: Suspension Problems. Please help! (w00t!)
I went to a place that does alignments and they told me that it isn't the camber or alignment. The rear driver side use to sit up a little higher but now it is sitting lower than before. The wheel is tucked. Something is up. Anyone know? Thanks
Old Nov 27, 2002 | 02:31 PM
dwnthehatch's Avatar
It's possible that you bent you control arm.
Old Nov 27, 2002 | 02:32 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
bent LCA or UCA. have the jockers at the alignment shop tell you which one it is. or go under the car and have a look. if you are really unlucky, the unibody is tweeked and the mounting points for the control arms are out of alignment. Or your spindle is bent.
stan
Old Nov 28, 2002 | 11:32 AM
poo flinger
Guest
Posts: n/a
Default Re: Suspension Problems. Please help! (90crxsi)
No the LCA and UCA is not bent. I measured all the arms to check for any bends. NOTHING! I do believe is the shock because that rear corner is sagging.
Kelvin Racing
Suspension & Brakes
Mar 29, 2009 08:21 PM
ccivic
Suspension & Brakes
Jan 31, 2005 11:28 AM
dornon13
Aug 16, 2004 02:18 PM
vtec94
Feb 12, 2003 09:39 AM
poo flinger
Nov 29, 2002 08:51 PM
