engine swap what do i do???
Old Nov 27, 2002 | 11:15 AM
MAGIC MUSHROOMS's Avatar
Default engine swap what do i do???
WHATS UP.. ok i got a 88 hatch dx shell. and i got a 99 hatchback
dx engine. what do i do to put the engine in? like what all do i need to change?
MAGIC MUSHROOMS
Old Nov 27, 2002 | 11:22 AM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
Default Re: engine swap what do i do??? (MAGIC MUSHROOMS)
you need to find a sohc cable clutch trans, wiring harness, dizzy(distributor)mounts, clutch, axles, and probably more but thats a start.
Old Nov 27, 2002 | 11:23 AM
Urban Business
Guest
Posts: n/a
Default Re: engine swap what do i do??? (1bad_EF)
you need to search
Old Nov 27, 2002 | 02:20 PM
JoshDM's Avatar
screw the 99' dx engine
fo b-series mang
Old Nov 27, 2002 | 05:58 PM
batman_22's Avatar
first of i think your name is gay you sound like a ******* homo and dont you drive the blue M&M car? hahaha
Old Nov 29, 2002 | 02:36 PM
skunkwhat's Avatar
Default Re: engine swap what do i do??? (batman_22)
Before you try and step you need to learn english, such as punctuation, and spelling because no one understands a damn word you type.
First off little eric, do you plan on staying with the the 88 dx fuel injection?
Or do you plan on going with the mpfi? of the 99 engine? Going with the 88 injection will simplify things and get the engine into the car, and up and running faster. The mounts that you have from the 88 engine should bolt up to the 99 engine. You can use your stock tranny/clutch/flywheel. You must use the 99 clutch if you use the 99 flywheel. Just use the 88 clutch/flywheel. Use your 88 dist. on the 99 engine. Use the wiring harness from the 88 engine and put it onto the 99, while using the 88 intake manifold and fuel injection. You may need to change out some of the sensors from the 88 engine and put them on the 99 because of different types of plugs. and there will be a bit of stuff on the 99 engine that will not get used(the 88 ecu will not look for these things)
[Modified by skunkwhat, 3:40 PM 11/29/2002]
Old Nov 29, 2002 | 07:06 PM
l0p3z's Avatar
i'm assuming that you and magic mushroom know each other, since you guys are both from "the dalles or", right?
Old Nov 29, 2002 | 07:36 PM
Malgerus's Avatar
wow. what a ghey reply. get a life!
Old Nov 29, 2002 | 08:43 PM
batman_22's Avatar
Default Re: engine swap what do i do??? (skunkwhat)
well you know what i dont really care what you think i just found out this was my bud of mine and thats why i said that
Old Nov 29, 2002 | 10:46 PM
Malgerus's Avatar
You're nice to your friends.
Old Nov 30, 2002 | 10:33 PM
skud_dusty's Avatar
Default Re: engine swap what do i do??? (Mr. S)
its something about this town...everybodies dicks
Crosseman
Transmission & Drivetrain
Jan 2, 2015 05:16 PM
89civic1.8T
Apr 3, 2003 06:13 PM
Nameless RB26
Nov 23, 2002 09:58 PM
MAGIC MUSHROOMS
Nov 20, 2002 02:41 PM
