Radiator keeps popping
Old Nov 27, 2002 | 09:21 AM
Integ718's Avatar
Default Radiator keeps popping
I did a search and read all the results but all that was suggested I already did. I have gone through 3 radiators in 4 months. I changed the coolant sensor, changed the radiator and bleed it, changed the hoses and they all start to leak at the top about a week later. Any ideas?
Old Nov 27, 2002 | 09:29 AM
TypeR_or_GSR's Avatar
Default Re: Radiator keeps popping (Integ718)
when i had my old 95 ls, i went through 2 radiators and finally found ou that i had a cracked head, hopefully that wont be the case for you
Brad's Avatar
whereabouts at the top? where the plastic and aluminum meet? or near the filler neck?
Old Nov 27, 2002 | 10:09 AM
MaNyFacEs's Avatar
Default Re: Radiator keeps popping (Brad)
I had that problem in my integ then i switched to a aluminum radiator and haven't had a problem since(knock on wood)
Old Nov 27, 2002 | 12:17 PM
Integ718's Avatar
It is leaking around the crimp area on top. I was wondering if a sticking thermostat can cause this problem?
flatblack-h22
Jan 3, 2009 08:33 AM
crazy_ham
Aug 4, 2008 12:37 PM
IgnitionZ05
May 5, 2007 10:50 AM
ziggz501
Mar 21, 2007 01:23 PM
dynastix9
Dec 18, 2005 06:33 AM
