Coolant fan on as soon as you turn the key and no vtec, any ideas?!!?
Well still not getting vtec for some reason, however I got no CEL codes at the moment. I do know that as soon as you put the key in the on position like 30 seconds later the coolant fan turns on and doesn't ever turn off after that.. I have already changed the Coolant sensor by the thermostat and the thermostat itself and the same thing happens...
Would this cause me to go into some sort of same mode?? I know there is another coolant temp sensor by the distributor, should I change that one as well??
Any help is greatly appreciated..
Did search, and everything else is in working order..
Rev limit currently at 6.5k RPMs
yellowturbo
Jan 7, 2004 02:44 PM
Jason kiDD
Nov 30, 2002 01:25 PM
