Squeaky Noise!
Hey guys, I have a problem with squeaks coming from my rear suspension. I have Arospeed drop springs that are about 2 years old and Tokico Illuminas 5-way shocks that are about 1 year old. I have stock rubber bushings and my car is a '97 EX. From inside the car while I'm driving I can hear the squeaking coming from what sounds like the springs or in that area. You can also notibly hear it from the outside while I'm driving. Also, if I get out of the car and push down on the rear end of it.. it squeaks. Any ideas what may be causing this annoying noise ?? It JUST started.
maybe it has dried up a bit and needs some luberication .. get some spary lube and try i'm pretty sure it would work ....
I realize now that this squeaking is only coming from the rear driver's side and it only makes a noise when the suspension compresses.
Any ideas ??? Should I take the wheel off ??
is suspension setup right? mine would squeak because it wasn't setup right
also could be your sway bar bushings
If I get out of the car and push up and down on the rear drivers side.. it's squeaks like crazy. I have arospeed drop springs and tokico illuminas 5-way.
are your springs sitting in on the rubber bushings on top and bottom?
Well, what would you suggest I do to tackle this situation myself ? Jack the one side up ? then what...
blackriceman
Jun 13, 2004 09:04 AM
