UKDM CTR wheels fit our Rs with no problems?
Old Nov 27, 2002 | 04:55 AM
machgo5go's Avatar
Default UKDM CTR wheels fit our Rs with no problems?
Anyone every tried these or info if they clear our stock Rs suspension?
Old Nov 27, 2002 | 04:57 AM
DutchITR1689's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (machgo5go)
Yes it will fit, but the offset and outer diameter (if you keep the CTR tire) will be incorrect....
Old Nov 27, 2002 | 05:05 AM
machgo5go's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (DutchITR1689)
Thanks for info, what effects with this incorrect CTR tires because I am debating buying oem tires 15's if this CTR setup works?
Old Nov 27, 2002 | 05:10 AM
sneakychaos's Avatar
Is that a 4door Accord Type R in the background? ::scratcheshead::
Old Nov 27, 2002 | 05:21 AM
Huh? 15" tires won't fit these wheels!!! Bigger outer diameter = worse acceleration and indicated speed on speedo will be lower.
I won't buy these CTR wheels because they are heavy (22 lbs or something)....
Old Nov 27, 2002 | 05:22 AM
Default Re: UKDM CTR wheels fit our Rs with no problems? (sneakychaos)
That's a JDM 4-door ITR.
Old Nov 27, 2002 | 05:33 AM
machgo5go's Avatar
What i meant is replacing my entire oem 15in USDM setup with these if they fit because my oem 15s are worn.
Old Nov 27, 2002 | 05:42 AM
Again, don't do it. They are very heavy!!!
Old Nov 27, 2002 | 05:59 AM
Keane Rated R's Avatar
17´s arent worth it unless they are very light... I would be interested to see a pic of a ITR with those wheels though....
Old Nov 27, 2002 | 07:58 AM
ITR#00-1077's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (Keane Rated R)
I would also like to see them on an ITR... I've seen the CW CTR rims on a DC5R though.... but would like to see it on a DC2R.... still I like those rims.... but the only debate is the weight..
Old Nov 27, 2002 | 10:19 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i spy a 4 door
Old Nov 27, 2002 | 11:24 AM
Hooch'n's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (dLo GSR)
Looks like Accord Type R wheels!
Old Nov 28, 2002 | 01:28 AM
Default Re: UKDM CTR wheels fit our Rs with no problems? (Hooch at 8400-RPM)
actually, no
my car on Accord Type R wheels
Old Nov 30, 2002 | 07:17 AM
Screaming Vtec's Avatar
This question was brought up on a UK honda site.
The general consensus was that the new CTR's although they are a 5x 114.3 pcd, have a smaller centre thingy.. (hub)
So the hole in the middle wont be big enough to fit over the Teg locating lip.
Not sure if this is correct thou so dont flame me if im wrong.
Would be worth making sure before buying them
Old Nov 30, 2002 | 07:29 AM
Nameless RB26's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (Screaming Vtec)
those look huge.
Old Nov 30, 2002 | 08:23 AM
austrian type-R's Avatar
Default Re: UKDM CTR wheels fit our Rs with no problems? (Nameless)
the rims are so big, he needs two parking spaces LOL j/k
Old Nov 30, 2002 | 11:49 AM
NZITR's Avatar
I'd be surprised if new CTR wheels had a smaller center bore size than the DC5/DC2 ITR. The Spoon DC5 ITR had CTR wheels on it. I have also tried fitting one of my 15" OEM DC2 wheels on the rear of an export DC5 ITR and the center bore fit was perfect. I guess there is always a chance that the length of the hub center on the DC2 and other Hondas may be longer and may not enable the CTR wheel to be fitted without modification of some sort. If they really are 22lbs I'd run a mile. I wouldn't use a 17" wheel over 16lbs.
Old Nov 30, 2002 | 06:34 PM
uber_nihilist's Avatar
Thanks for info, what effects with this incorrect CTR tires because I am debating buying oem tires 15's if this CTR setup works?Huh? 15" tires won't fit these wheels!!! Bigger outer diameter = worse acceleration and indicated speed on speedo will be lower.
Yeah but weren't not all into drag here. Check this article out, bigger is better!: http://www.grassrootsmotorsports.com/plustest.html
Pai Mei
Jun 29, 2012 10:00 AM
98ctrwanabe
Feb 22, 2010 01:39 PM
boricuatuning
May 22, 2009 05:56 PM
4thgenx42
Jul 11, 2007 09:37 AM
eG179
Jun 8, 2004 11:30 PM
