EMERGENCY****** passenger door window will not close!
Old Nov 27, 2002 | 02:41 AM
funkylemons's Avatar
Default EMERGENCY****** passenger door window will not close!
Any ideas? 99 civic si... its not the lock switch.. and if it was a fuse neither window would close, the drivers side did close.. the motor doesnt make sound or anything!.. i had everything apart to resintall the stock cd player, and i had the doors off to reinstall the stock speakers, and stock wiring.. i know i didnt cross any wrong wires..all plugs are plugged in.. i dont know what to do, and i have to be out the door right now.. im on my way out of town!
Old Nov 27, 2002 | 06:13 AM
Desslok's Avatar
Default Re: EMERGENCY****** passenger door window will not close! (funkylemons)
You checked all the plugs, even the one that goes from the door to the car? Also, do you have a window lock switch on yur driver side? Did you try driver side and passenger side switches. If you need to you can always run 12 V straight to the motor just to get it up.
Old Nov 27, 2002 | 10:15 AM
FifthGearOnline's Avatar
Default Re: EMERGENCY****** passenger door window will not close! (sp)
check the window lock
Old Nov 27, 2002 | 10:50 AM
GSRaCeRbOI's Avatar
you sure your wire harness to window switch is plugged in? I remember when I was doing something w/ the door panel off and the switch unplugged.. the window wouldn't roll up.. even from the driver side control..
check the window lock switch and re-check the wiring and fuses... is the window "stuck" fell off its track/guide rail?
dunno if all checks out.. could be the motor or control mechanism/regulator..
Joey Mitchell
Oct 18, 2018 04:59 AM
scclark
Honda CR-V & Element
Aug 29, 2016 05:38 PM
92widebodyeg
Nov 19, 2007 07:00 PM
ryan_61684
Honda Civic (2001 - 2005)
May 23, 2007 02:57 PM
funkylemons
Nov 27, 2002 06:27 AM
