Homemadeturbo.com @ the Dyno's
Well we made a few runs with some various cars last Saturday..
Jeff Ls/Vtec (NA) (AbaZ)
175.4hp 126.0tq
Beau Turbo B16a (10psi)
205.0hp 159.3tq
Adam Turbo D16z6 (10psi) Stock 165k Miles!
180.8hp 186.9tq
Dustin Turbo ZC (9psi)
171.1hp 148.6tq
The runs were pretty decent, We had some difficulties tuning Beaus car, it seemed like everything we did it was just making things worse. I thought for sure it would be about 230hp or so. I think we just need to spend a bit more time to get it figured out.
My car seemed to do ok with my New LS/Vtec, It has mods I/H/E and the new JG intake manifold. Stock Pistons, Stock Cams, tuning with the Zdyne Gold SECU. I started with a base of 164, and gained 11hp on the dyno. The cars peak Horsepower was @ 8100rpms.
My Best Friend Adams car (civic hatch) was just very impressive on the Dyno, pumping more Torque that Horsepower! It did that on just about every run. He is running a very cheap 500 buck turbokit, with a 450cc DSM/Controller Hack. Pretty damn good for 165k on a stock engine.
Dustins car did pretty well too, I wish we could have taking his exhaust off on the dyno to see how much of a gain it would have added. The greddy exhaust is just to small for Turbo apps.
Beaus 88 Crx SI
Dustins 88 Crx HF
Adams 92 Civic Hatch SI
Of course My Camara died, so I couldnt take any pics of my car
Jeff
[Modified by AbaZ, 6:16 AM 11/27/2002]
175.4hp 126.0tq
205.0hp 159.3tq
180.8hp 186.9tq
171.1hp 148.6tq
Beaus 88 Crx SI
Dustins 88 Crx HF
Jeff
thanks for the pics, now i know which cars to look out for
btw i figured out why my car was missing, my plugs had no gap in em, runs pretty good now
[Modified by S13 slide, 6:46 AM 11/27/2002]
Beaus Setup, B16a (1g)
B17 Cams
A1 LS Tranny
ACT stage 2 Clutch
Zdyne Gold SECU w/ 450cc dsm injectors
T3/T4 .63a/r Turbo
Deltawastegate
Custom Exh Turbo Manifold
3 inch Exhaust (straight pipe w/ 2 resonators)
Semi P&P Head.
Starion Front Mount..
Thats all I can think off the top of my head, his car is definatly the fastest..
Ya ya, everyone wants to see my Race Turbo ZC dyno, and finished! Its still in the works, I have just put it on hold for awhile, I am probabaly going to put a Turbo on this LS/Vtec first, then get back to work on the race car.
Jeff Frank
B17 Cams
A1 LS Tranny
ACT stage 2 Clutch
T3/T4 .63a/r Turbo
Deltawastegate
Semi P&P Head.
Jeff Frank
what does adam's car have ?? damn good numbers !! im hopin our set up will do the same !!
i want that **** also... i wanna go turbo now!! having more tq than hp it sjust lovely.. cant past that...
sweet dustis car should be simalar to mine cause im gonna be running the same setup
zc w/ 14b correct?
[Modified by 88hondahatch, 10:19 AM 11/27/2002]
zc w/ 14b correct?
How early did the torque start peaking in Adam's car? Could you scan the dyno sheets? They were all awesome runs, congrats on the great numbers.
More torque than HP
More torque than HP
uh........wow.........that z6 is crazy. Yeah Id like to see the sheets there too. Also how bout that ZC, not a bad run at all, whats the setup like, and has it ever run above 9 psi?
zc w/ 14b correct?
zc w/ 14b correct?
the CRX did boost 5psi for about half a day then the charge pipe fell off completely and was boosting like 2psi (5psi was ok but 8psi kicks ***). i fixed the charge pipe and its been 8-9psi sence....
B17 Cams
A1 LS Tranny
ACT stage 2 Clutch
T3/T4 .63a/r Turbo
Deltawastegate
Semi P&P Head.
Jeff Frank
B17 Cams
A1 LS Tranny
ACT stage 2 Clutch
T3/T4 .63a/r Turbo
Deltawastegate
Semi P&P Head.
Jeff Frank
good numbers. what compression is he running...?[Modified by speeddave, 2:58 AM 11/28/2002]
9.1 c/r on the Turbo B16a
I will try to get my scanner working again and get the sheets up. Whats funny, Adams D16z6 sheet probably looks the worst out of any of them. It starts making pretty good power around 3500-4000rpms.
It does seem pretty odd, in fact we were all pretty amazed with Adams Numbers, He did 5 runs to prove himself, and each time, it kept getting better! I added more timing, and we played with fuel control a bit, and every run he got more Torque than actual horsepower, which is VERY ODD in a Honda engine. In fact I was looking at alot of peoples Turbo GSR's and Turbo B16a's and they dont even produce that kind of torque (in stock form 5-7psi) Its just crazy. My guess it has something to the custom spring setup for the wastegate....
Jeff
[Modified by AbaZ, 5:07 AM 11/28/2002]
Jeff
what exactly is done to the ZC ? Any port and polish or anything?
