Which HID is nicer? OEM JDM or philips??
Old Nov 26, 2002 | 07:57 PM
Petah's Avatar
Default Which HID is nicer? OEM JDM or philips??
Like the topic says....whichHID system is better? I have read (not certain) that in order to install factory HID on a JDM conversion, you will have to bend the AC lines a bit. I am assuming you won't have to do this with a philips 9006 HID kit. But which one is better? Which one will have better lighting?
Old Nov 26, 2002 | 08:36 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Which HID is nicer? OEM JDM or philips?? (eg-six)
OEM Honda HID ballast and bulbs in a OEM HID JDM headlight housing will look and peform best as the optics were designed to reflect HID beams. So to answer your question, OEM HID is better IF its in a OEM HID headlight housing.
Mase's Avatar
OEM HID Projector housing is specifically made for HID's, whereas the non-HID's are not. You will have a better output w/ the OEM HID's. As for installin the OEM HID's, they were very simple, it took me about 10 seconds to bend the a/c line, its not bad at all. If you have the money, go for the OEM HID's. I did. and Im glad. (I also had a Hella HID kit before and it wasnt as nice as the OEM HID's)
Hope this helps
Old Nov 26, 2002 | 09:19 PM
jdmspoonitr's Avatar
Default Re: Which HID is nicer? OEM JDM or philips?? (Mase)
oem hid's look nice...i have some on my car. The only con is that the left beam will always shine higher than the right no matter how much you adjust it. They are made to drive on the right side of the road. keep this in mind. Right now I have mine adjusted so the left beam does not hit on coming traffic....but because of this my right side is quite low.
Old Nov 26, 2002 | 10:24 PM
B2FiNiTY's Avatar
Default Re: Which HID is nicer? OEM JDM or philips?? (jdmspoonitr)
OEM HID
Old Nov 26, 2002 | 10:29 PM
JaeOne3345's Avatar
Default Re: Which HID is nicer? OEM JDM or philips?? (B2FiNiTY)
just make sure u stay with 4300..and not 6000
Old Nov 26, 2002 | 10:30 PM
Reid's Avatar
Global Moderator
Default Re: Which HID is nicer? OEM JDM or philips?? (JaeOne3345)
6000k is for uneducated people who don't understand why BMW/S2000/Audi/etc look the way they do.
Old Nov 26, 2002 | 10:31 PM
EddieHatchBlack's Avatar
OEM HID
Old Nov 26, 2002 | 10:33 PM
JaeOne3345's Avatar
Default Re: Which HID is nicer? OEM JDM or philips?? (Reid)
reid..always telling **** like it is someones gotta do it
DAlexsanderC
Mar 17, 2011 06:36 PM
jdm phantomx
Dec 29, 2004 02:16 AM
hobo79
Sep 24, 2004 08:10 AM
FritzInTN
Sep 21, 2002 01:07 AM
Xia0w0ng
Aug 12, 2002 11:05 PM
