valve adjustment question
Old Nov 26, 2002 | 07:34 PM
stRtypR25's Avatar
Default valve adjustment question
are you supposed to loosen both locknuts on each cylinder or just one?
sorry if this sounds like a we-todd-did question but i am lost
Old Nov 26, 2002 | 07:53 PM
stRtypR25's Avatar
Default Re: valve adjustment question (stRtypR25)
anyone
Old Nov 26, 2002 | 07:54 PM
stRtypR25's Avatar
anyone??
Old Nov 26, 2002 | 08:02 PM
Philly_NBP_R's Avatar
go here...
http://www.c-speedracing.com/howto/v...lveadjust.html
and do a search, we've covered this over an over again
Old Nov 26, 2002 | 08:15 PM
stRtypR25's Avatar
Default Re: valve adjustment question (Philly_NBP_R)
i went there but i still am not sure if you are supposed to loosen one of the locknuts or both.
Old Nov 26, 2002 | 08:31 PM
stRtypR25's Avatar
i did a search and i cant find the answer to my question
Old Nov 26, 2002 | 08:35 PM
infinkc's Avatar
huh? both locknuts? there is only one nut on each valve if im correct.
Old Nov 26, 2002 | 08:42 PM
Dave-ROR's Avatar
Default Re: valve adjustment question (infinkc)
he meant per cylinder. Like both intake valves on each cylinder.
Adjust one valve at a time.
Old Nov 26, 2002 | 08:46 PM
Bbasso's Avatar
Default Re: valve adjustment question (Dave-ROR)
Yup, "Adjust one valve at a time."
Old Nov 26, 2002 | 08:50 PM
stRtypR25's Avatar
what i am trying to say is on the exhaust side (#1 cylinder) there are two adjusting screws and two locknuts, am i supposed to loosen both locknuts or just one?
Old Nov 26, 2002 | 08:51 PM
Dave-ROR's Avatar
uhhh i answered your question already..
Old Nov 26, 2002 | 08:55 PM
stRtypR25's Avatar
so i should loosen one of the locknuts turn the adjusting screw, then tighten the the locknut and then do the same thing for the other locknut/adjusting screw that is next to it?
Old Nov 26, 2002 | 08:56 PM
Dave-ROR's Avatar
Old Nov 26, 2002 | 09:00 PM
stRtypR25's Avatar
thanks for your patience and not flaming the **** out of me
Old Nov 26, 2002 | 10:20 PM
kkim's Avatar
Helms service manual might be a great investment for you. It covers this and more, step by step, with drawings and pictures.
I can't begin to count how much money owning this manual has saved me.
good luck with the adjustment.
Old Nov 26, 2002 | 10:31 PM
2dark2bslow's Avatar
Default Re: valve adjustment question (kkim)
yeh, i need one of dem betches. anyone got one for sale or know where i can get one online cheap?
Old Nov 26, 2002 | 10:42 PM
kkim's Avatar
Default Re: valve adjustment question (2dark2bslow)
http://www.helminc.com
Old Nov 29, 2002 | 06:17 PM
ultimatehonda's Avatar
Do you need a special 10mm wrench to losen and tighten the lock nut on the valve?
Old Nov 29, 2002 | 08:24 PM
SlapSmak's Avatar
Default Re: valve adjustment question (ultimatehonda)
you dont need a special wrench, just a firm hand with the screwdriver when you re-tighten the locknut. remember to do one valve at a time, loosen the locknut, insert the feeler gauge between the cam and arm, tighten or loosen the screw with your screwdriver then when it is perfect, tighten the locknut without letting the screwdriver move. remember to check the clearence one more time with the locknut tight to make sure you didnt get the clearence too tight. then move onto the next. I am doing mine in the morning, autoX on sunday.
Old Nov 29, 2002 | 08:49 PM
DA MUGEN 1's Avatar
Default Re: valve adjustment question (SlapSmak)
Do you and your car a favor find someone who has done this before and knows what they are doing to show you how to do it. Also I would not even suggest even attempting to work on your car without some type of manual! Even the most professional mechanics use the factory manuals so someone trying to learn how to work on their car definetely needs one!
dperry
Sep 4, 2014 03:41 AM
ohheynix
Apr 30, 2012 10:00 PM
HeartOfRRR
Dec 16, 2008 01:49 PM
nY's FiNeSt
Jul 7, 2003 09:07 AM
