91 ls into 94 del sol
Old Nov 26, 2002 | 07:30 PM
LS Powered Del Sol's Avatar
Default 91 ls into 94 del sol
somebody help me out, i have the complete 91 integra that im using for an engine swap into my new del sol. the dol was a, S. ive already got the hasport mounts, obd1 ecu, distributer, a new oil pan, a new clutch, the works. anyways, can stock b18a fuel injectors be wired up to work with the obd1 ecu and dist?? or am i screwing myself over by not buying the new injectors? if it is absolutly neccessary, does anyone have a set?? hasport says i can use a set from any obd1 civic or integra, is this true? has anyone done a similar swap? please let me know asap, the del sol comes on saturday, and the swap is starting that day
thanks alot
Old Nov 26, 2002 | 07:36 PM
flip b18b's Avatar
Default Re: 91 ls into 94 del sol (LS Powered Del Sol)
the injectors in the sol will work just fine
Old Nov 27, 2002 | 03:38 AM
Default Re: 91 ls into 94 del sol (hondafreakc5)
thats the problem, the del sol has no motor. i have a cx hatxh that im trading for the sol, will the injectors from there work?
TeamRED_07
Jan 29, 2016 05:24 PM
jlk16188
Aug 1, 2012 08:42 AM
almostjdmeg
Jan 14, 2010 09:56 PM
89JDMcrx
May 22, 2004 11:16 PM
