N1 vs GT Spec
Old Nov 26, 2002 | 11:47 AM
Shawn's Avatar
Default N1 vs GT Spec
They both seem to come into play well with high horsepower engines, anyone got pics of the two and info about the in terms of performance....dyn??? etc. Thanks Shawn
Old Nov 26, 2002 | 11:54 AM
Spikey's Avatar
Default Re: N1 vs GT Spec (Shawn)
please elaborate what you are talking about...
Old Nov 26, 2002 | 11:55 AM
Brian's Avatar
Try this https://honda-tech.com/zerosearch
Old Nov 26, 2002 | 12:00 PM
Shawn's Avatar
Default Re: N1 vs GT Spec (Spikey)
Apex N1 and Gt Spec exhausts, i thought they didnt make the gt spec for itrs yet, but yet i have found a place that does. but my question is, what are the differences in terms of performance, sound, appereance, etc.
Old Nov 26, 2002 | 12:18 PM
Spikey's Avatar
Usually, any N1 style exhaust, one that has a very small, thin muffler can, will be fairly loud. A freer flowing N1 style exhaust usually does perform better than a quieter, more restrictive exhaust system. But that is not always the case and you will have to do some research to find out which will work for you. As for appearance, that is very subjective and up to your own personal preference
Old Nov 26, 2002 | 12:22 PM
DeL SLo's Avatar
the GT Spec is a copy of the N1 except the whole cat-back is ss. its like how the Super Racing Medallion is to the Racing Medallion.
Old Nov 26, 2002 | 12:32 PM
Spikey's Avatar
Default Re: N1 vs GT Spec (DeL SLo)
thanks
Old Nov 26, 2002 | 12:57 PM
csufweed's Avatar
actually the GT Spec usually runs larger piping as well. however, the piping is usually TOO large for its applications, causing less than optimal power. they dont call it GT Spec for nothing... its probably better suited for HIGH horsepower applications cuz of the increased diameter. on the WRX it made less torque than the N1 cuz the piping is larger... so this shows that it is designed for higher hp applications.
Old Nov 26, 2002 | 01:57 PM
Shawn's Avatar
Default Re: N1 vs GT Spec (csufweed)
Are there many differences between the GtSpec and the CtLight exhausts by Apex?
Old Nov 26, 2002 | 02:01 PM
Smitdog's Avatar
Old Nov 26, 2002 | 02:07 PM
StinkyTofu's Avatar
Default Re: N1 vs GT Spec (Smitdog)
I just checked out the inlinefour.com site, and they have a picture of the GT Spec. It looks like that there are almost NO bends from the cat all the way to the muffler. This would probably mean that the piping goes under the LCA and will give you crappy ground clearance.
Old Nov 26, 2002 | 02:21 PM
GReddyB18C's Avatar
Default Re: N1 vs GT Spec (StinkyTofu)
Hey guys,
Just got off the phone with Brandon @ inlinefour.com. He said the GT Spec exhaust does go under the control arm. The piping is 60mm and it is a one piece unit. Cheers.
-Shawn
Old Nov 26, 2002 | 07:58 PM
Shawn's Avatar
Can anyone inform me on what the know about the Gt Light exhaust and the differences from the Spec? Thanks, Shawn
Old Nov 28, 2002 | 04:39 AM
00MRSi's Avatar
I believe they just recently started making the APEXi GT spec exhaust for Hondas. I'm pretty sure GT spec exhaust is mainly for boosted cars. They usually have larger piping up to 95mm. I've only seen the GT spec used on boosted cars. GT spec is also quite expensive. If you're staying NA then the APEXi N1 (60mm piping) will be sufficient. I have the N1..
topp_dawg_g
Jan 29, 2008 03:22 PM
stuie08
Oct 26, 2006 11:15 AM
4gen
Jun 25, 2006 01:26 PM
NrG
Jan 27, 2006 10:19 AM
isca21
Apr 26, 2004 07:04 AM
