H&R sports + Koni yellow = way too low
The front is way way too low for me. I dont understand why it would even drop it this much. I have it on the highest perch of the two, so thats not the reason.
The rear turned out fine, I put it on the higher of the three perches and I have about a two finger gap.
What reasons would make it drop way over the 1.75" drop the h&r sports are suppose to give it?
Anyone?
Anyone?
Yes. My car has been lowered for the last 3 years. I was just replacing out my old bec-techs.
My only thoughts are possibly switching out the front springs for some eibach pro-kits.
[Modified by GAccord, 12:23 PM 11/26/2002]
i cant really see **** from that pic but this is the way HR sports are supposed to set on your car.
http://community.webshots.com/album/49657264HGwiJu
http://community.webshots.com/photo/...49657356tYaWnW
i took the liberty of removing the stock mudguard flap crap things since those pix
[Modified by ArchAngel Sabastian, 12:26 PM 11/26/2002]
Not sure, do the konis for the 5th gens have the metal spring holder(bad description), what the spring sits on? Sort of like a bowl. Possible that you have that flipped over? I remember an issue like this on my 4th gen.
[Modified by unACCORDInated, 6:31 PM 11/26/2002]
Yes it does sit in a "bowl", but from the looks of it, it wouldnt matter which way the bowl was.
that doensn't make sense gaccord...when i just had the sport springs i had a perfect drop. completely even. then i installed the koni yellows and the front stayed the same, but the rear was wayy to low. so i took apart the rears and raised the perch and now its perfect. i think you installed your springs upsidedown, that **** happens. make sure on the front springs, the writing on the spring is upsidedown. thats how it should be.
too low??? HAHAHHAHHAHAHA
<--- has to take front bumper off to get ferrari floor jack under front jack point
[Modified by SOHCArchangel, 9:03 PM 11/26/2002]
basically....,
basically....,
Wow this thread turned worthless.
[Modified by ArchAngel Sabastian, 3:57 PM 11/27/2002]
first off you need a better pic
[Modified by WhoNeedsVtec, 5:05 PM 11/27/2002]
