Stock exhaust system with new header
I'm planning on getting a DC Sports 4-2-1 header for my ITR. My exhaust system is stock. Is there any point buying a header without upgrading the exhaust system?
Anytime you can improve the flow of air in and out, you will generate more power. The best case would be to also upgrade your intake, as well as cat/cat back as well.
But like most, I had to upgarde mine one part at a time
[Modified by Joker, 10:09 AM 11/26/2002]
Most people here go with the JDM OEM 4-1, or DC Sports JDM 4-1 header. THere is a ton of stuff on H-T about both. I'd try doing a search under both names, and then buy what you want. It is your car
So what your saying is that a header alone wont't give very much unless you at least put on cat back?
at the very least, go with a dc jdm header or honda oem jdm header, and get a cat that will accomodate the larger header, because stock cat isnt going to fit and is restrictive anyways. Stock exaust will work...but for maximum gains, you will need to upgrade later on
http://www.ipsracing.com/engine/exha...sound_cat.html
Everything should fit neatly together with the stock exhaust?
dc header->race cat->stock exhaust
Stock header collector is 2" OD, not 2.25"!!!!
The catback is 2.25" OD with some bottlenecks...
The difference between JDM header + stock exhaust and JDM header + full 2.5" exhaust is about 3 HP...
If you are going to use the stock exhaust, don't forget to remove the first bottleneck (right after the cat).
p.s. check my sig...
dc header->race cat->stock exhaustYup... fits just fine... as long as the cat is made for your application.
https://honda-tech.com/zerothread?id=204632
The inlet of the cat is 2.5" so it fits to the header, but is the outlet also 2.5"? In that case I'll need some sort of adapter cause stock exhaust is 2.25" after cat... Does anyone know where to get one of those?
Ok so I dont need an adapter of some sort to make the carsound cat.
Yeah, JDM header with stock exhaust is a fine set-up.....It helps to have an exhaust but the header is where you will see big gains.
ok.. any USDM header (1.75" collector) is NOT worth it.
go for anything that has 2.5" (anything, your choice)
[Modified by arren123, 7:04 PM 11/27/2002]
