psi for slicks
Old Nov 26, 2002 | 07:36 AM
964dgsr's Avatar
Default psi for slicks
What psi do you guys run your slicks at?
Old Nov 26, 2002 | 07:39 AM
b18b98's Avatar
Default Re: psi for slicks (964dgsr)
I've known people to run on 11psi on their slicks. I believe it varies on the size of slicks you are using.
Old Nov 26, 2002 | 07:42 AM
964dgsr's Avatar
Default Re: psi for slicks (b18b98)
I'm gonna be using 20x8x14, what psi should I run it at? Thanks for replies in advance.
Old Nov 26, 2002 | 08:15 AM
ExospeedAMcrx's Avatar
those are small slicks and shouldnt be dropped lower than 10psi. they actually work good at even 12lbs or so. if you have to go lower and lower to hook up, i;d go with a bigger slick.
Old Nov 26, 2002 | 06:16 PM
EVOCELICA's Avatar
New User
differs on size and track conditions, I could spin the **** out my 24.5's at 11psi and some days with track conditions ideal they would grab like a bitch.
Old Nov 26, 2002 | 11:49 PM
Mista Bone's Avatar
D Tranny Guru
from my PERSONAL useage..................
20x8x14 on 14x6 rims, 12 psi. Lower than that and slicks will spin on the rim.
20x6x16 on 14x5 steelies, 14 psi. Went 14.85 all motor, nuf said.
Old Nov 27, 2002 | 12:30 AM
ninesecrx's Avatar
Default Re: psi for slicks (Mista Bone)
Id run them at 6-8 pounds...that works on any size slick.
Old Nov 27, 2002 | 04:55 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: psi for slicks (Arn)
i use 8 lbs.
Old Nov 27, 2002 | 06:41 AM
AussieK24's Avatar
Default Re: psi for slicks (turbotypeR)
Do you guys that go under 10psi have pinned slicks ie screwed to rims????
Old Nov 27, 2002 | 09:46 PM
turbologist's Avatar
i use 8 lbs.
Old Nov 27, 2002 | 10:26 PM
2FASTDC2's Avatar
Default Re: psi for slicks (drealboostedhybrid)
I usually start at around 12psi and lower it from there, stop once you start losing mph.
Old Nov 28, 2002 | 08:55 AM
25 Year Member
Default Re: psi for slicks (b16a4me)
not me!
hondahvn
Nov 11, 2003 09:04 PM
fast93accord
Aug 7, 2003 07:52 AM
Jockobo
Jul 24, 2003 09:58 PM
UNDER PRESSURE
Apr 21, 2003 03:25 PM
HX_Guy
Jul 14, 2001 10:37 PM
