93 legend, abs code, need help
ok, my gf's mother drives a 93 legend, auto tranny.
abs light is on.
i havent had a chance to get the MIL code, im assuming the plug is in the standard place, under passenger glove box?
anyway, it was checked at a mechanics shop, and she was told that her speed sensor needs replacement.
#1, why would a faulty speed sensor throw an abs code?
#2, if this is true, i need one asap. anyone got one? anyone know if other speed sensors will fit so i can hunt for it?
thanks a ton...
abs light is on.
thanks a ton...
so after some research, i found a great article.
(FYI - good reference) http://www.babcox.com/editorial/bf/bf70210.htm
im now led to believe its the wheel speed sensors. im no familiar with this car, but i assume these are the little black boxes near the brake lines on each wheel? how the hell do i know which one it is?? are they all the same so i can buy one and try one at a time?
The ABS code will tell you which wheel speed sensor circuit is the problem. All the sensors are different. You need the correct one for the corner that you are replacing.
so i just read theABS trouble codes, and am getting two codes; a 4 (4 fast flashes), and an 8 (same pattern).
i cant find abs codes anywhere.. can anyone point me in the right direction, please??
[Modified by Leo95SE, 7:48 PM 11/29/2002]
fyi, think i found summin usefull..
thanks..
1 Pump motor over-run Motor fuse, relay, pressure switch
1-2 Pump motor circuit Motor relay unit fuse
1-3 High-pressure leakage Solenoid
1-4 Pressure switch
1-8 Accumulator Gas leakage
2-1 Parking brake switch-related Fluid level switch, BRAKE light
3-1 FR Wheel pulser
3-2 FL Wheel pulser
3-4 RR Wheel pulser
3-8 RL Wheel pulser
4-1 FR Speed sensor
4-2 FL Speed sensor
4-4 RR Speed sensor
4-8 RL Speed sensor
5 RR, RL Speed sensor Modulator
5-4 RR Speed sensor "
5-8 RL Speed sensor "
6 F or R Fail-safe relay
6-1 Front Fail-safe relay
6-4 Rear Fail-safe relay
7-1 Solenoid-related problem ABS B1 fuse
7-2 "
ABS B3 fuse, Front fail-safe relay
7-4 "
Rear fail-safe relay
thanks..
1-4 Pressure switch
3-1 FR Wheel pulser
3-2 FL Wheel pulser
3-4 RR Wheel pulser
3-8 RL Wheel pulser
4-1 FR Speed sensor
4-2 FL Speed sensor
4-4 RR Speed sensor
4-8 RL Speed sensor
7-2 "
7-4 "
Those rear sensors can be a bit$h to get out of the backing plates in the rear. To get the new sensor back in after the old one gets out can be a pain as well, that is unless you force it then it breaks and you start all over.
Progen
Dec 27, 2013 02:26 AM
