anyone here use a PYR chipped P28?
Old Nov 26, 2002 | 04:27 AM
red civic standard's Avatar
Default anyone here use a PYR chipped P28?
i will be putting a '98 JDM ITR motor in my 91 hatch and do not know which ecu to use. it will be running OBD1.
i was going to use the kenji p28 but i can get a decent deal on a PYR p28. anyone have any experience with this ecu?
Old Nov 26, 2002 | 04:40 AM
Darkteg's Avatar
New User
Default Re: anyone here use a PYR chipped P28? (red civic standard)
kenji's ECU works great on EDM/JDM engine
Old Nov 26, 2002 | 05:28 AM
GM2000ITR's Avatar
New User
PYR is the best ECU program we have tried (& it's all we use now - unless Hondata, AEM or other standalone is available). On the dyno, it produced better results than Skunk2 or Mugen. The biggest difference is that it does run very rich.
Old Nov 26, 2002 | 05:51 AM
Default Re: anyone here use a PYR chipped P28? (GM2000ITR)
hey GM2000ITR,
are the ITR motors that you tune heavily modded?
my mods list will be minimal: CAI, exhaust, JDM 4-1, flywheel. Will I still see the same gains using the PYR ecu?
Old Nov 26, 2002 | 07:44 AM
GM2000ITR's Avatar
New User
We use the PYR program for just about every ITR motor (be it ITR w/ heavy mods, light mods, LS/VTEC, etc.) Peter really knows what he is doing. The greatest example I can remember was my friend Keith's EK hatch w/ ITR motor. Basic mods(I/H/E, gears, CTR cams, light flywheel, FPR, etc.), we saw a 22whp increase from simply adding the PYR P28 (w/ OBDI harness). Skunk2 and Mugen could only muster up 14-15 more ponies(not bad, but not 22!) Hope this helps!
Old Nov 26, 2002 | 08:09 AM
kappa's Avatar
danngg that is very impressive ... this will certainly be something ill look to invest in the future (When it jdm B18C swap comes in )
Old Nov 27, 2002 | 07:31 PM
gamby's Avatar
Jesus!!! Does PYR make a P28 for the B16A2???
Their website???
Thanks
Old Nov 27, 2002 | 08:30 PM
GM2000ITR's Avatar
New User
Default Re: anyone here use a PYR chipped P28? (gamby)
here 'ya go!
http://pyr-racing.com/
Old Nov 28, 2002 | 12:30 AM
GZR4DR's Avatar
Its just the mugen chip put in the P-28 ecu. I used the same exact prog on my car. Its definately a good ecu/chip combo. If you really want the ecu chipped, let me know i can get it done for you prob at a better price and quick turn around.
I will also say this, Hondata is better however it is a bit more expensive. For the money the chipped P-28 is a great ecu.
[Modified by GZR4DR, 1:31 AM 11/28/2002]
Old Nov 30, 2002 | 03:36 AM
TurboR1391's Avatar
Default Re: anyone here use a PYR chipped P28? (GZR4DR)
I used to have the PYR chipped P28 in my old hatch. I used it strictly for drag racing because of the strong fuel curve. I won't lie you burn gas like a V-8 with this ECU, but it is the **** and worth every penny. If my R was NA I would be using it.
Old Dec 1, 2002 | 11:55 PM
lilxvtecxpwr's Avatar
Default Re: anyone here use a PYR chipped P28? (TurboR1391)
i ran peter's program for awhile. it ran nice, ate alot of gas though.
*the check engine light was always lit with this chip...do any of u riding this peter's program do this?*
Old Dec 2, 2002 | 05:34 AM
GM2000ITR's Avatar
New User
WERD!
Old Dec 2, 2002 | 05:50 PM
GZR4DR's Avatar
ECU light should not be on. Mine never was. Remember P-28 does not check for knock sensor. If chipped correctly, light should not be on. Unless of course your wiring is messed up. Also i only got like 18mpg with the ecu because it loves to guzzle gas.
Old Dec 2, 2002 | 07:31 PM
TurboR1391's Avatar
No, I never had a check engine code with the PYR P28.
Old Dec 2, 2002 | 08:47 PM
gamby's Avatar
The gas-guzzleing thing is strange to me. My B16A2 made way more power by leaning the hell out of the fuel curve, especially up top. Strange to see a program that goes the other way.
Maybe I just need a P28 prgrammed to stock B16A2 specs, and I'll just use my V-AFC w/ it again...
Tuning: it's always confusing...
Old Dec 2, 2002 | 08:49 PM
acura_typer's Avatar
Banned
typically, the ECU's that run the richest have the most timing in them to prevent detonation.
hybrid_vtec
16
Feb 3, 2013 07:38 AM
99TypeR_ek
Mar 18, 2007 05:44 PM
mingbling
Feb 27, 2004 10:46 AM
bluesaint
Feb 27, 2003 12:16 PM
giooooo
Oct 18, 2002 09:17 AM
