h23 turbo and hondata..what ecu?
Old Nov 25, 2002 | 09:40 PM
BoostedH23a1's Avatar
Default h23 turbo and hondata..what ecu?
matt at hondata says p72.. im not a VTEC but i want my secondaries to work... what ecu do i use...
Old Nov 25, 2002 | 09:42 PM
boomslang's Avatar
Default Re: h23 turbo and hondata..what ecu? (BoostedH23a1)
If you want the secondaries to work, your only option is a P72. Unless you want to wire up a rpm activated switch for them to go on.
Old Nov 26, 2002 | 05:17 AM
Finest's Avatar
The only ECU that can control the IAB's, and compatible with Hondata is the P72. They haven't cracked the P13 ECU yet, so no dice there.
OR else you can wait for the Skunk2 H22 manifold.... *wait* BUHAHHAHAHHA!
Old Nov 26, 2002 | 05:48 AM
symba's Avatar
Default Re: h23 turbo and hondata..what ecu? (Prelude_RCR)
Definately the P72...I checked into that personally a month or so ago. I've since decided to go with AEM but that's just cause there is a good tuner for aem within 20 miles instead of me driving to Tampa -120 miles- for hondata.
Old Nov 26, 2002 | 08:52 AM
DLB1994's Avatar
Default Re: h23 turbo and hondata..what ecu? (symba)
take the secondaries out they are not going to help you with a boost car and go with a p28
Old Nov 26, 2002 | 08:58 AM
sgT's Avatar
sgT
Default Re: h23 turbo and hondata..what ecu? (DLB1994)
no. not p28, p74/75
Old Nov 26, 2002 | 09:12 AM
DLB1994's Avatar
Default Re: h23 turbo and hondata..what ecu? (sgT)
i know you a Honda dealer but you can configured it to run non-vtec engine that's what i been thinking about with hondata 2b with a set of 720cc
the reason i can get them cheap and easy to find
i just seen a few people have problems with the LS ECU's
Old Nov 26, 2002 | 01:10 PM
P72 thats a GSR isnt it... mines not VTEC does that matter..
Old Nov 26, 2002 | 01:32 PM
DLB1994's Avatar
you can configured it to run non-vtec engine thats what hondata says
HAMOTORSPORTS
Oct 24, 2017 12:00 PM
DR
Texas -OK -LA (Sales)
Jan 20, 2007 03:11 PM
cpforyou
Sep 24, 2005 05:31 PM
tai....
May 12, 2005 08:40 AM
Nextelbuddy
Jul 24, 2003 10:43 AM
