Steering Wheel Still Shaking--Help a Noob out.
Old Nov 25, 2002 | 07:09 PM
Ef Whore's Avatar
Default Steering Wheel Still Shaking--Help a Noob out.
This 45-75 m.p.h. wheel shaking makes me feel like i'm driving a big turd. Also occurs when brakes are lightly pressed, but dissapears when stomped on. EVERYTHING is new- powerslot rotors, ebc pads, energy master kit , ball joints/tie rods, tires are balanced, bled the system, new pep boys cv's, what the freig is up? I Hate this shaking bullshit.Help me i'm going nuts.
Old Nov 25, 2002 | 07:16 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Steering Wheel Still Shaking--Help a Noob out. (Ef *****)
even though the rotors are new, doesn't mean they are not warped. have them checked. the wheels, especially aftermarket, have the tendency to not sit properly on the hub, first thing you can do is to jack the car up and loosen the wheel lugs and retighten them in the proper fashion, cross, equaly tightening each untill all are tight (how many times can YOU say tight in one scentence? ) or get hubcentric rings. rotate your wheels, that helps a lot also. make sure your steering rack is adjusted properly, mine was loose, after two minutes with a gas wrench under the car, shaking diminished and the steering got much tighter (lol).
your inner tie rods might be shot as well. go under the car and (make sure the car is very stable!!) shake the steering rack and tie rods around.
good luck
stan
[edit] i kunt sple
[Modified by 90crxsi, 8:18 PM 11/25/2002]
Old Nov 25, 2002 | 07:28 PM
CimorelliCRX's Avatar
Default Re: Steering Wheel Still Shaking--Help a Noob out. (90crxsi)
How are your rear drums? Normally if your brakes are pressed and the wheel shakes, its your rear drums.
Old Nov 25, 2002 | 07:32 PM
Ef Whore's Avatar
Default Re: Steering Wheel Still Shaking--Help a Noob out. (CimorelliCRX)
i've changed the shoes but never had thedrums resurfaced--should try that and see what happens? But how can that make the wheel shake it is not connected to the rack at all?
Old Nov 26, 2002 | 05:03 AM
serious's Avatar
are your tires at the correct pressure?
Old Nov 26, 2002 | 06:20 AM
TheJuggalo's Avatar
My car did that too. Had a wheel alignment done and it fixed it. Drives like new!
Old Nov 26, 2002 | 06:34 AM
Ef Whore's Avatar
Default Re: Steering Wheel Still Shaking--Help a Noob out. (TheJuggalo)
I think I'll get it aligned and see what happens. Thanks buddy.
Old Nov 26, 2002 | 06:35 AM
spiceisler's Avatar
Have the wheels speed-balanced!
Old Nov 26, 2002 | 07:04 AM
USDM 4G VTEC's Avatar
well i rotated my tires and now it shakes a lil also like u say
i say bc the tires are all worn out and its out of balance... also my car needs aligment bad.. so , il say align the car, and have u r wheels balance...see if it helps
KEVlN's Avatar
New User
Default Re: Steering Wheel Still Shaking--Help a Noob out. (clean90Si)
yeah, this fixed my problem.
-kev
Ohbebe75
Oct 24, 2015 07:50 AM
rocru
May 29, 2012 11:36 AM
mikecp
Jul 3, 2010 11:03 PM
teletekman
May 3, 2006 09:15 AM
crxaddikt
Feb 10, 2004 08:55 AM
