Zex nitrous with turbo???
Old Nov 25, 2002 | 05:37 PM
zojirushi's Avatar
Default Zex nitrous with turbo???
Is this a possible combination or is this a bad idea?
Old Nov 25, 2002 | 05:48 PM
filetofit
Guest
Posts: n/a
Default Re: Zex nitrous with turbo??? (zojirushi)
Doesn't the ZEX kit work by raising your fuel pressure when the nitrous kicks in? Since you are running the hack I would think that you'd run rich since the kit doesn't know you have larger injectors.
Old Nov 25, 2002 | 06:41 PM
inline976's Avatar
you're probably going to want to run a wet shot so you don't detonate. you can run the zex with the hack and probably get away with it for awhile..but your motor will go to ****. it will still run a little lean
[Modified by inline976, 3:48 AM 11/26/2002]
Old Nov 25, 2002 | 06:52 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Zex nitrous with turbo??? (inline976)
when your running boost its not he greatest idea to run a very large shot. People have seen 45hp increases buy running a 30 shot. It cools down the intake temp and denser is always better. By the step up to a better FMU so you dont blow your engine. Just remember that tunning is your best friend. Just my .2 cents though.
Blaze
[Modified by Blaze45, 3:55 AM 11/26/2002]
Old Nov 25, 2002 | 07:18 PM
zojirushi's Avatar
Default Re: Zex nitrous with turbo??? (Blaze45)
actually, i only plan on running no more than 30 shot. Just a little something to get me down into the 13's.
Old Nov 25, 2002 | 07:27 PM
NXAccordTO4B's Avatar
im using a nx direct port kit on my turbo setup. Works greats. however im spraying a 100 out the hole.
Lonewolf1983
Oct 3, 2014 02:55 AM
Dave01
Dec 17, 2003 01:24 AM
Rory Breaker
Jan 21, 2003 08:23 PM
blacklude
Oct 14, 2002 01:57 PM
vspec12
Nov 15, 2001 03:16 PM
