What's the Lowdown on the CTR N1 Crank Pulley?????
Old Nov 25, 2002 | 01:29 PM
AK94GSR's Avatar
Default What's the Lowdown on the CTR N1 Crank Pulley?????
I have searched this subject but wasn't enough info or peoples opinions on this pulley.
I plan on taking off both P/S and A/C and was looking for a good crank pulley.
let me know your experiences or thoughts on this
Old Nov 25, 2002 | 01:30 PM
sgT's Avatar
sgT
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (AK94GSR)
get unorthodox instead
Old Nov 25, 2002 | 01:31 PM
Doctor CorteZ's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (sgT)
or shave down the OEM pulley.....
cost me about 40 bucks including a re-balance.
Old Nov 25, 2002 | 01:42 PM
Willard's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (Doctor CorteZ)
Old Nov 25, 2002 | 01:44 PM
sackdz's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (Willard)
I've got one sittin' in the garage. Still need a pulley holder to install it though. $75 new.
[Modified by sackdz, 5:45 PM 11/25/2002]
Old Nov 25, 2002 | 01:46 PM
Willard's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (sackdz)
Air gun y0!
Old Nov 25, 2002 | 01:49 PM
sackdz's Avatar
Still need a pulley holder to install it though.Air gun y0!
Oh yea, I forgot I have some impact sockets now!
I've broken like 3 19mm's with the impact
Old Nov 25, 2002 | 03:50 PM
AK94GSR's Avatar
So you guys recommend Unorthodox???
Old Nov 25, 2002 | 03:52 PM
MackSpeed-616's Avatar
[sarcasm] oh no! what about the HARMONIC DAMPENER?!? [/sarcasm]
Old Nov 25, 2002 | 05:48 PM
Willard's Avatar
good luck setting the timing.....
Old Nov 26, 2002 | 01:53 PM
AK94GSR's Avatar
Well yeah that's true about the timing. So can the N1 crank pulley harm your engine???
Old Nov 26, 2002 | 02:02 PM
sgT's Avatar
sgT
So you guys recommend Unorthodox???good luck setting the timing.....
The timing marks on the 3 unorthodox crank pulleys are right.
Old Nov 26, 2002 | 02:07 PM
ITRinEJ1's Avatar
yea
due to the sheer high velocity of the lightweight single pulley at 15k rpm it will fly off the motor, sheeer off the crankshaft, bounce around the and leave a big whole at the bottom of the block.
i'll save this link and tell you "i told you so" when it happens
Old Nov 26, 2002 | 02:53 PM
BERT-O's Avatar
I know someone local that had his over 1 year and not have any problems with it.
He bought it to see how bad it will hurt his engine but to date, no problems. I know he will be tearing his motor apart this upcoming Christmas break to see if there's any signs of uneven wear. He's doing this cause he ought to go with a higher compression than he currently runs.
As of matter of fact, I bought one from Leo that I'm going to run on my next setup soon, I hope .
Old Nov 26, 2002 | 02:58 PM
2dark2bslow's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (SANBST)
i say f#$@ the headache and worries of putting an aftermarket one on. Doesnt anyone else think the stock one is fine?
peas out!
Old Nov 26, 2002 | 04:18 PM
-Whitey-'s Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (2dark2bslow)
the ctr n1 is factory honda
Old Nov 26, 2002 | 04:26 PM
sneakychaos's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (ITRinEJ1)
yea
So is that what happened to your last motor. I always wondered.
Old Nov 26, 2002 | 11:11 PM
sgT's Avatar
sgT
peas out!
what headache??
stock too heavy, ctr = stock as well = too heavy
aluminum is key
Old Nov 26, 2002 | 11:44 PM
itr1244's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (CX SIRII)
yeah so it cant be a "aftermaket" pulley
Old Nov 27, 2002 | 03:30 AM
Civic Minded's Avatar
Read up!
https://honda-tech.com/zerothread?id=219450&page=1
Old Nov 27, 2002 | 03:38 AM
Back in Black's Avatar
Rather OG
The CTR pulley is fine. No problems here.
Old Nov 27, 2002 | 06:07 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (Jason Franza)
CTR is working out fine for me (Knocks on wood).
Old Nov 27, 2002 | 06:35 AM
owen_the_soyboy's Avatar
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (Apex i ITR)
weight difference between Unorthodox and CTR N1 is........?
Old Nov 27, 2002 | 08:45 AM
sgT's Avatar
sgT
Default Re: What's the Lowdown on the CTR N1 Crank Pulley????? (owen_the_soyboy)
a lot
my unorothodox i can twirl around on my pinky finger
Old Nov 27, 2002 | 08:54 AM
CHEETAH's Avatar
are you a road racer who keeps going every 15 mins for a 20 min at a time at like 9 or 10K rpm ? then shave the stock one which has a harmonic balancer or get the CTR N1 or similar type with same material but doesnt have balancer. the UR aluminum will expand too much with all that stress if used in this scenario... similar to what happens with aluminum flywheels from the stress and heat.
If you use for daily driving and occasionally race drag or road, then the unorthodox aluminum will be fine just check clearance as UR tends to vary bore sizes so they dont fit as tight as the stocker or CTR N1 whne fitting around the crank.
I personally recommend the N1 pulley even with the added weight when compared to the UR one. If you wanna get those, see Leo Kwok he's got the best deals by far ...
Greg
