Squeeky 93 Accord!!!!???? WTF?
Old Nov 25, 2002 | 07:47 AM
schoolboi's Avatar
Default Squeeky 93 Accord!!!!???? WTF?
Hey wussups, I'm new in here and had a tech question and was wondering if anyone could help me out. I have a 93 accord 10th anniversary and it SQUEEKS. I mean literally squeeks. It squeeks when I turn the steering wheel to the left and whenever I go over bumps. I though that it was possibly my struts so I changed in some KYB's and some coilovers..... Didn't work, my brother said possibly something wrong with my axles.... changed them.... still squeeks. I know it's not power steering fluid, and I tried spraying all the suspension parts with grease and lubing them up. Still the same thing. It seems to be coming mostly from the driver side but when I jacked it up and shook it a little from the rotors, the noise comes from under the engine from the passenger side. Finally my cousin told me it's most likely a loose nut or bolt. So.... I tightened everything down that I could see. What IN THE BLAZEZ CAN IT BE!!!!???? If someone has had this problem before, please let me know what they did. IE which bolts to tighten, what parts you needed to replace. Oh yeah, I have seen three or four accords with the same squeeking problem. But they don't seem to bother with fixing it so they're no help. Any advice is great. Thanks!
Old Nov 25, 2002 | 09:10 AM
briq4's Avatar
Default Re: Squeeky 93 Accord!!!!???? WTF? (schoolboi)
Did you take off your sway bar mounts and grease them? They can make a nasty creaking noise if they get dried out.
Old Nov 25, 2002 | 09:32 AM
schoolboi's Avatar
Default Re: Squeeky 93 Accord!!!!???? WTF? (briq4)
I've already tried that man... anything else someone could think of????
Old Nov 25, 2002 | 09:34 AM
schoolboi's Avatar
I wouldn't want to take my car to the shop and then get a diagnosis of a loose nut or something little. However, I don't want to ignore it like the other accord owners and let my ride squeek like a beeezatch.
Old Nov 25, 2002 | 09:38 AM
Accord94DX's Avatar
are the spring insulators seated properly?
the twin cities = retarded.
Old Nov 25, 2002 | 10:36 AM
Charlie Moua's Avatar
HAHAH
i have the same car man. ever since i got it back form honda the interoir vibrates and buzzes more. I'm from MN too
Old Nov 25, 2002 | 10:39 AM
Accord94DX's Avatar
Default Re: Squeeky 93 Accord!!!!???? WTF? (Charlie Moua)
ill be damned. three twin cities accord owners in the same thread......
Old Nov 25, 2002 | 11:00 AM
StimpyBoy's Avatar
It sounds like you checked the suspension, but did you check the condition of the rubber bushings? On my Accord (92 LX CDN), the rubber bushings are cracking and are generally in bad shape. I'm pretty convinced that the squeaking on my car is from that.
You said you greased and lubed the suspension, but I thought I'd just share one experience. Like the 3 or 4 other Accords, I'm not going to bother getting it fixed. One thing I will say though, now that winter is here, the squeaking has disappeared for some reason.
Anyhoo, GL, share the solution to your problem if you get it fixed.
Old Nov 25, 2002 | 12:24 PM
Howitt's Avatar
Default Re: Squeeky 93 Accord!!!!???? WTF? (StimpyBoy)
I have a polyurethane camber kits and when they arent greased they sweak like hell. Also when I needed new brake pads the brakes squealed like hell to
Old Nov 25, 2002 | 01:51 PM
Accord94DX's Avatar
Default Re: Squeeky 93 Accord!!!!???? WTF? (Howitt)
yeah, my ST rear swaybar made a ton of noise with the polyurathane bushings, even lubed up with the ST jizz.
i spooged them all in silicone paste and they have been quiet ever since.
Old Nov 25, 2002 | 03:35 PM
sauceman's Avatar
I'd be willing to bet it's your lower ball joint that's dryed up. It'll soon start to loosen, and you will have to replace it.
Old Nov 26, 2002 | 07:54 AM
schoolboi's Avatar
Other than the squeeks, the car runs fine. Thanks for all the advice guys. I guess I'll just replace the rubber bushings with poly's, keep them greased up. If that don't work, replace my lower ball joint. And if that still doesn't work.... SAY HELLO TO MY WINTER CAR! He he he.
[Modified by schoolboi, 5:05 PM 11/26/2002]
Old Nov 29, 2002 | 10:32 AM
EuRoBrO's Avatar
If you have a camber-kit, check that and grease it.
accordman=]
Feb 15, 2009 09:42 AM
msand9898
Dec 14, 2007 12:47 PM
93AccordLx
Apr 2, 2003 05:59 PM
