fuse question about the car horn
Old Nov 24, 2002 | 10:37 PM
LB CRX's Avatar
Default fuse question about the car horn
94 civic dx
recently my horn stopped working and i checked the fuse located in the engine bay and it was fine. i also checked to see if the horn was unplugged or anything.
i dont have the little panel guide for the fuses under the steering wheel. also, the dome light stopped working around the same time the horn did. is there a fuse under the steering wheel that links both of these together?
one more thing, the guys at the shop just did my alignment and they had to unbolt the steering wheel. before i start taking **** apart, is there a plug that links to the steering wheel to the horn inside the car? TIA
Old Nov 24, 2002 | 11:31 PM
eg_nezay's Avatar
Default Re: fuse question about the car horn (LB CRX)
check your ground in the steering. If that doesnt work, check the horn itself with direct wires from the battery.
fryguy190
10
Oct 1, 2008 07:14 AM
wrestler
Feb 20, 2007 04:06 AM
Vagabund07
Jan 12, 2007 08:48 AM
XxSOHCDriVerxX
Oct 1, 2003 06:24 AM
.MilanoRex
Mar 23, 2002 03:00 PM
