B18C5 Type R Engine Volumetric Efficiency?
Old Nov 24, 2002 | 07:02 PM
vtec.dc2's Avatar
Default B18C5 Type R Engine Volumetric Efficiency?
Measuring Volumetric Efficiency.
Anyone know a formula for that, how to measure it?
[Modified by vtec.dc2, 1:26 PM 11/25/2002]
Old Nov 24, 2002 | 07:04 PM
vtec.dc2's Avatar
Default Re: B18C5 Type R Engine Volumetric Efficiency? (vtec.dc2)
trying to figure out the airflow of type r engine
one formula I found:
AIRFLOW = 0.5 x Engine Size x RPM x % V/Efficiency
Old Nov 24, 2002 | 09:29 PM
vtec.dc2's Avatar
anyone?
Old Nov 24, 2002 | 09:31 PM
baonest1's Avatar
damn.. thats outa my league..
you lost me at Volume
Old Nov 25, 2002 | 12:15 AM
Lsos's Avatar
I would say it gets right up to around 100% if not more at the higher rpms.
Old Nov 25, 2002 | 02:30 AM
vteg's Avatar
New User
There is no one volumetric efficiency for a give engine. It varies throughout the rpm range, and will match the torque produced by the engine. Max VE occurs at peak torque. Depending on the car VE may be anywhere from the 80's to just over 100 in an NA car at peak. Intake tuning and scavaging can cause VE to exceed 100% for short periods in the range.
From what I know, only car manufacturers have the instruments to give the true VE for an engine.
Old Nov 25, 2002 | 08:28 AM
Jack Black's Avatar
Normally you'd measure the airflow and use that to determine the VE, not the other way around. You can make a venturi-style airflow meter that will give you decent results. It's kind of a lot of work, though, with about half of the work being the math.
It'll probably be a lot easier to find the numbers online, though. If you just need a decent approximation, you can assume 100% VE and use the above formula.
As others have noted, VE varies throughout the RPM range due to intake and exhaust tuning. Since the ITR engine is highly tuned, it probably stays in the area of 100% in a large part of its RPM range.
Old Nov 25, 2002 | 09:22 AM
vtec.dc2's Avatar
Default Re: B18C5 Type R Engine Volumetric Efficiency? (vteg)
thats correct, i should of stated my question better (going to edit on top)
my question would be on how to calculate volumetric efficiency of an engine.. I found this calculator from
https://honda-tech.com/zerothread?id=248299
not sure if hp you enter is whp or at the crank.
Old Nov 25, 2002 | 09:25 AM
vtec.dc2's Avatar
Default Re: B18C5 Type R Engine Volumetric Efficiency? (itr01-0851)
is there a formula to measure airflow without the meter?
Old Nov 25, 2002 | 09:39 AM
Jack Black's Avatar
Don't know of one/can't think of one off-hand, but then I'm a bit out of practice. Try a Google search for "measure airflow"
Old Nov 25, 2002 | 09:54 AM
vtec.dc2's Avatar
is there a formula to measure airflow without the meter?Don't know of one/can't think of one off-hand, but then I'm a bit out of practice. Try a Google search for "measure airflow"
yep.. will try that.. thanks
Old Nov 25, 2002 | 07:41 PM
Lsos's Avatar
As has been noted, VE matches or is tightly related to the torque produced by an engine. There's probably some way then to figure out VE based on the torque, then...but it seems like a hell of a lot of work finding the exact relation between VE and torque in the first place.
D0hctor
Jun 11, 2017 04:23 PM
95ILS
May 16, 2005 07:34 AM
hillbillybob
Jun 24, 2004 08:31 AM
