Cleanup of head bolt threads in block...
Old Nov 24, 2002 | 05:27 PM
Sonny's Avatar
Default Cleanup of head bolt threads in block...
I'd like to cleanup the headbolt threads in my block. The block is pretty old (87) and a couple of the head bolts were pretty crusty coming out.
The size is M11 x 1.25.
This is not a hard size to find for a standard length tap. Unfortunately, a standard length tap is way too short.
To those who have done this...where did you get an extension tap of that size?
The threads are not stripped. I just want to have a nice clean bite for my new ARP studs.
Thanks,
Sonny
Old Nov 24, 2002 | 09:07 PM
Sonny's Avatar
Default Re: Cleanup of head bolt threads in block... (Sonny)
8 views in the Tech forum?
Sonny
Old Nov 25, 2002 | 04:41 AM
Farnsrocket's Avatar
I bought a tap when I built my block and ran into the same problem, tap was too short. I tried to use it and it kept getting caught up and I was unable to control it going into the threads on my B18C1. So I just sprayed brake cleaner in the threads and air hosed it out, ran my Arps in and out of them and made sure it was smooth.....no problems. You would almost have to have an extension welded on to the tap.......not sure what else to tell ya.
Old Nov 25, 2002 | 08:30 AM
earl's Avatar
Default Re: Cleanup of head bolt threads in block... (Farnsrocket)
I take an old 1/4 drive socket and jam it over the end of the tap. Use only one long extension. Kind of frightening threading the tap in and losing sight and control.
gooblinn258
Apr 22, 2014 08:50 AM
jmoorepghpa
Classic Hondas
Jan 13, 2009 10:59 PM
SilentHatch
Jan 6, 2007 12:06 PM
pip9
Jun 15, 2004 03:58 PM
brinks
May 19, 2004 03:39 PM
