Is the myth about toda Bs true?
Old Nov 24, 2002 | 03:54 PM
98cwitr's Avatar
Default Is the myth about toda Bs true?
Are they really breaking timing belts? If so...why?
Old Nov 24, 2002 | 04:07 PM
EK MONEY's Avatar
Default Re: Is the myth about toda Bs true? (98cwitr)
yes they do, you need toda timing belt.
Old Nov 24, 2002 | 04:15 PM
Eric R's Avatar
...yeap, because the stock belt is not designed to withstand the higher drag from a wilder cam than stock or spec A. So the belt snaps at continuous high rpm use. Need to buy a reinforced TODA or PE timing belt.
Old Nov 24, 2002 | 04:33 PM
Instg8er's Avatar
Default Re: Is the myth about toda Bs true? (Tweety R)
Yes, spend the extra $180 so you don't have to pay $1K+++ for a top-end re-build
Old Nov 24, 2002 | 04:52 PM
Dave-ROR's Avatar
yes and no. some do, some don't. Yack used stock belt for a long time, some broke theirs. Strangely this seems to be a north america problem as it's not prevelent elsewhere.
IMO stock belt tensioned correctly and inspected occasionally is fine, but if you want the piece of mind get the PE or Toda belts.
Old Nov 24, 2002 | 04:54 PM
Reid's Avatar
Global Moderator
Default Re: Is the myth about toda Bs true? (Peagreenhatch)
Being that there are people using Toda B's and a stock timing belt without any problems, what makes you say this?
Old Nov 24, 2002 | 04:56 PM
Dave-ROR's Avatar
Default Re: Is the myth about toda Bs true? (Reid)
Reid: Because it's RED y0. Red=mad speed y0
Old Nov 24, 2002 | 09:04 PM
98cwitr's Avatar
Default Re: Is the myth about toda Bs true? (Dave-ROR)
um yeah
my redline is at 8,400 and I take it to 8,900 all day so i might as well get to timing belt. its not a really DIY job $500 at the dealership and $150 getting the retired Honda mech. to do a side job. To me though cams, cam gears and valve springs aren't DIY either.
Old Nov 24, 2002 | 09:30 PM
Shark Tank's Avatar
get a helms its easier than you think. i did mine myself with my spec b's and no problems at all
Old Nov 24, 2002 | 09:38 PM
StinkyTofu's Avatar
Default Re: Is the myth about toda Bs true? (CART fan)
Some people have their stock belts last 1000 then they snap. I had my stock belt on for 5500 miles before switching over to my PE belt. My stock belt did not have any signs of wear and it appeared to look brand new. Although installation is a major factor, i also think that the honda timing belts are not all created equally.
Old Nov 24, 2002 | 09:57 PM
Dave-ROR's Avatar
um yeah
your redline is 8400, so I'm assuming a stock ECU? If so, your fuel cut is 8500. The only way you are hitting 8900 is if you keep misshifting on downshifts.
It is a DIY job. It's even easier then the cam gears and you might as well just do both at the same time.
edit: err meant to say cams, cam gears, etc. on me.
But I could understand the cams scaring you, but the cam gears are easy for most people, just don't use a impact gun on the bolts.. lol
[Modified by Dave-ROR, 2:07 AM 11/25/2002]
Old Nov 28, 2002 | 10:27 AM
Hondata's Avatar
Default Timing belts
There is no problem with the Toda cams, nor any other cams that I know of. The #1 reason for a timing belt to break is because it is too tight. Tension the belt when the engine is hot as the belt will tighten a lot from cold. When cold the belt will go fairly loose. BTW the toda belt is a pink/purple color.
Old Nov 28, 2002 | 10:36 AM
GokuSSJ4's Avatar
stock belt is fine if install correctly . im running Spec D's with no problems .
Old Nov 28, 2002 | 10:44 AM
Blade's Avatar
New User
Default Re: Is the myth about toda Bs true? (Spoon1)
It's a myth, I've got about 27,000 miles on a stock belt with spec B's. Some people over estimate their technical ability and think they're qualified to install these parts, so they end up snapping their belt.
Old Nov 28, 2002 | 11:00 AM
Dave-ROR's Avatar
Default Re: Is the myth about toda Bs true? (Blade)
Blade: IIRC sgT snapped a stock belt before with todas.. does he have no skill in installing cams in Bseries motors then?
Old Nov 28, 2002 | 11:04 AM
migs's Avatar
No skill at all.
Old Nov 28, 2002 | 03:45 PM
itr1244's Avatar
um yeah
Old Nov 28, 2002 | 04:11 PM
K1R's Avatar
K1R
running b with oem belt. here
Old Nov 28, 2002 | 06:03 PM
Black R's Avatar
25 Year Member
Default Re: Timing belts (Hondata)
I actually run my PE belt tighter than stock - I don't want it jumping teeth at high rpms... I also don't run a cut valve cover except to tune.
Some people break belts, and some don't. Most of us chalk it up to install error or lack of vigilance in keeping an eye on the oem belt with a cut valve cover..
To each his own. For peace of mind, I installed a Power Enterprise timing belt - others may run a red (toda) one...
43MA
Dec 19, 2004 09:43 PM
integrasi
Sep 21, 2003 09:30 PM
JPP
May 30, 2003 09:53 PM
iTR.EX
Nov 19, 2002 08:06 PM
rockwilda
Apr 21, 2002 10:16 PM
