should I do a clutch install at the same time I do my turbo install?
Old Nov 24, 2002 | 12:31 PM
pub's Avatar
pub
Default should I do a clutch install at the same time I do my turbo install?
Clutch already starts to slip on the stock b18b.
..just wondering if I should install a new clutch first, then install turbo?
would it be any easier to install the clutch with some parts out of the way?
..what clutch would you guys recommend for ~8psi daily driven (stop, go traffic @ times - so as close to stock feel)
Thanks
-Justin
Old Nov 24, 2002 | 12:42 PM
HybridKOOP's Avatar
Default Re: should I do a clutch install at the same time I do my turbo install? (pub)
Either order, but put it in before you boost... or you will be pissed on how bad it slips.
ACT hybrid street disc with extreme pressure plate.
Old Nov 24, 2002 | 02:44 PM
ski_rebel_3's Avatar
Default Re: should I do a clutch install at the same time I do my turbo install? (HybridKOOP)
I put my ACT street disc with extreme pressure plate clutch in before I installed the turbo. If you are going to install the turbo soon then just do them both together, otherwise do the clutch first.
Old Nov 24, 2002 | 02:53 PM
DeepSi's Avatar
Default Re: should I do a clutch install at the same time I do my turbo install? (ski_rebel_3)
Install the clutch before and break it in. then install the turbo and tune it and emjoy it. ACT HDSS here and loving it in the Bay Area traffic.
Old Nov 24, 2002 | 06:17 PM
swrdply400mrelay's Avatar
Default Re: should I do a clutch install at the same time I do my turbo install? (DeepSi)
go with an ACT Xtreme Plate with the hybrid street disc
dakidd05_99
Jul 20, 2008 08:11 PM
eg6T
Apr 12, 2006 06:34 PM
jabronee76
Oct 18, 2003 10:58 PM
Snafu-Si
May 30, 2002 11:36 PM
