Radiator Fan not working
Yep, search... there've been at least 5 or 6 threads on this just in the last month. Things to check: fan relay in the underhood fuse box, coolant level in your radiator, thermosensor switch near thermostat housing on the block.
Check the fan motor...connect a 12v source directly to the wires coming off the fan to the plastic connecter...the fan should spin.
does your car overheat? at idle? while driving?
if it overheats at idle chances are its the fan switch, motor, or relay.
if it overheats while driving, your thermostat may be stuck...
haha yeh check for coolant level too, or simply flush the whole system and fill er up again. DONT forget to bleed all the air out!
94egR
Jun 16, 2008 11:18 AM
