P06 to P28 ECU conversion
Old Nov 24, 2002 | 11:17 AM
charjacq's Avatar
New User
Default P06 to P28 ECU conversion
Anyone knows how to convert a P06 ECU to a P28 ECU? Info, links?
Also, if anyone want to trade performance programs, I have quite a few.
Thanks
Old Nov 24, 2002 | 11:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: P06 to P28 ECU conversion (charjacq)
Might want to IM the user Katman or try e-mailing Kenji Plennert at kenji211@tampabay.rr.com
As far as I know the motherboard has to be an IPT unit or you won't be able to convert it.
Good luck y0!
Old Nov 24, 2002 | 01:59 PM
Zer0DazE's Avatar
Default Re: P06 to P28 ECU conversion (B18C5-EH2)
depending on what p06 you have, some can be converted. someone (perhaps Katman) posted pics on another board of one that had been converted.
Old Nov 24, 2002 | 03:35 PM
charjacq's Avatar
New User
Default Re: P06 to P28 ECU conversion (Zer0DazE)
That's what I have heard too. I need detailed information on this, maybe someone can help?
Old Nov 25, 2002 | 04:35 PM
charjacq's Avatar
New User
Any more info on this???
Old Nov 28, 2002 | 10:00 AM
charjacq's Avatar
New User
Anyone?
Also, does anyone know what different OBD0 ecus can be chipped and how?
Thanks
Old Nov 28, 2002 | 10:14 AM
Eee Pee's Avatar
I got a p28 for 75 bucks at a junkyard...try that.
Old Nov 28, 2002 | 07:29 PM
charjacq's Avatar
New User
Default Re: P06 to P28 ECU conversion (E Prep)
I don't want to buy one, I want to know how I can convert a P08 to a P28. I know it's possible, I just don't seem to be able to get any info on this...
Old Nov 29, 2002 | 07:17 AM
Zer0DazE's Avatar
here is a compairson of a p28 and a p06. my q is what flavor are those 5 pin transistors.
Old Nov 29, 2002 | 08:21 AM
charjacq's Avatar
New User
Is that the only difference between a P28 and a P06?
Old Nov 29, 2002 | 09:00 AM
Zer0DazE's Avatar
yep, and the transistors are sk5151... or so i was recently told. the question is, what uF is the blue cap?
Old Nov 29, 2002 | 09:25 AM
Darkteg's Avatar
New User
probably manual/auto trans...
check this:
http://pgmfi.crx-forum.org/resources...ification.html
Old Nov 29, 2002 | 10:50 AM
Zer0DazE's Avatar
Default Re: P06 to P28 ECU conversion (Darkteg)
check this:
nope, but you can see the little blue cap in both pics
Old Dec 9, 2002 | 06:49 AM
charjacq's Avatar
New User
Anybody has more detailed instructions?
Old Dec 9, 2002 | 06:58 AM
eg6ajk's Avatar
blue caps are: 3.3uF electrolytic tantalum
only successful board that has been converted to VTEC from non-vtec (P06) is the 11FO. 1720 board does not seem to be working with the DOHC VTEC roms, tried it many times, without luck.
courtesy of JK (here is the IPT 11fo board ready to be vtec)
Old Dec 9, 2002 | 08:29 AM
civictypenos's Avatar
Default Re: P06 to P28 ECU conversion (eg6ajk)
ttt,id like more info on this as well
Old Dec 9, 2002 | 09:24 AM
ggrrssyydik
Guest
Posts: n/a
Default Re: P06 to P28 ECU conversion (civictypenos)
the only one i have been able to convert to a p28 is the FO board there are like two or three different motherboards that are used on p06,7&8 ecu's. the fo is your best bet...
Old Dec 9, 2002 | 10:34 AM
charjacq's Avatar
New User
So what are the different parts needed?
Old Dec 10, 2002 | 05:40 PM
Default Re: P06 to P28 ECU conversion (ggrrssyydik)
i have the po6 that everyone says can be converted,what parts are needed and where do they go,thanx.
Old Dec 10, 2002 | 06:50 PM
eg6ajk's Avatar
not sure if you guys can't see but look at the pic above, its got the components and the postion...
Old Dec 11, 2002 | 05:16 AM
charjacq's Avatar
New User
Yeah, but what parts are those? What are the specs?
Old Dec 11, 2002 | 06:08 AM
Zer0DazE's Avatar
after looking again, i see a couple of differences between the pic i posted and the one eg6ajk posted. in the pic i posted there as a ceramic cap in C63, but in the other pic there isnt but there is a resistor (looks like 1 brown stripe, i cant make it out) in J14.
also you (eg6ajk) dont happen to know off the top of your head what that transistor in E is? i assume the same as the other ones in the area (but its better to be safe than sorry)
[Modified by Zer0DazE, 10:46 AM 12/14/2002]
Old Dec 11, 2002 | 07:45 AM
thats it,just those 4 pieces will change it,seems too easy,what are the specs on those,thanx.
Old Dec 13, 2002 | 02:27 PM
ttt
90cobraclone
Northern California (Sales)
Sep 21, 2011 07:42 PM
ICEMAN707
Feb 27, 2007 09:52 PM
1994typeR
Mar 23, 2005 07:15 PM
