How bad is it that I run my daily driver without a Filter on the turbo?
Im curious too..how the hell do you run a filter on a 60-1? Do I need some kind of 4' elbow and coupling or what? I dont even think that **** will fit...
well i dont have a filter, im daily driven for about the last 2-3 months. of couse i spend like 20bucks on my turbo and want a B16 soon (it will get a filter)....
put a filter on it.
you ever cleaned your stock air filter at all? notice any little rocks.
Those rocks = bye bye turbo/engine
Spendy $20 on a filter or spend $6k on a new engine/turbo setup. your chioce
[Modified by machaf, 1:09 PM 11/24/2002]
very true...but anyone know where I can get a pipe to lead from my turbo so I can put a filter on it???
yo, i have a 4 inch inlet, and really no room to put a filter there between the turbo and the framerail, is there a really (really) thin filter with a 4 inch inlet thats available? or do i have to use a pipe with a filter, any help would be great, thanks
if you cant get a filter for it you can use a lil wire mesh(like the pasta strainer)the put like a piece of cloth over that then another piece of mesh over that. Just in case u dont have room for a filter
where can you buy the filter piping?
i bought drag piping, but i guess it doesn't come with the air filter piping.
Example- T3. 2.5" inducer diameter. You'd get a 180° mandrel bent u 2.5" pipe and a cone filter with a 2.5" throat that will flow at least 350 CFM. Then some 2.5" sillycone couplers and hose clamps, cut the u pipe to fit the bends you need; badda bing, badda boom, done.
i used screen from a screen door. cut out a square and through it on the end of the turbo w/ a clamp. when i went to the track, i took it off and ran bare. works fine.
I bought a 4" exhaust mandrel bend elbow, T-bolt clamps and 4" coolant hose from Napa and made my intake for my 60-1. Oh yeah, I also ordered the K&N from them as well.
[Modified by Farnsrocket, 5:29 PM 11/24/2002]
ZCHF
Apr 22, 2003 08:46 AM
