crx si cluster swap to 89 crx dx help!
Old Nov 24, 2002 | 09:29 AM
type_racerz's Avatar
Default crx si cluster swap to 89 crx dx help!
i know this isnt plug and play. i rewire it to the same color as the si but some color dont have it. my rpm gauge dont work my mph and fuel works. NEED HELP WIRING!!!!!!
Old Nov 24, 2002 | 01:54 PM
Camshaft's Avatar
Default Re: crx si cluster swap to 89 crx dx help! (type_racerz)
were the connectors the same ?
what did you rewire ?
Couple people have told me it was plug and play
cam
Old Nov 24, 2002 | 02:13 PM
CivicNut's Avatar
i took a crx si cluster (not sure what year exactly) and put it in my 89 civic dx and so far so good. it was just plug and play (10min job, most of the time looking for the damn screws to unscrew )
Old Nov 25, 2002 | 09:00 AM
EF_LSVtec's Avatar
Check out this link and retrace your steps...
http://www.geocities.com/twisted91ci...ap_diagram.htm
Old Nov 25, 2002 | 02:52 PM
mr. carpenter's Avatar
Default Re: crx si cluster swap to 89 crx dx help! (EF_LSVtec)
print or copy that link, go to your car, and make sure it all goes where it should.
Old Nov 25, 2002 | 03:13 PM
Default Re: crx si cluster swap to 89 crx dx help! (mr. carpenter)
it work! how come when i open the door it doesnt show the guy with the seat belt????
Old Nov 25, 2002 | 03:52 PM
if it's not working properly, you've got a 90-91 cluster or a broken one. you've got an 89 so by moving wires make you're 89 plug configuration match the 90-91 plug configuration. you don't have to cut wires . use a needle or safety pin to move the plastic piece inside each plug to slide wires out. do them one at a time , there are six wires that have to be cut and moved to the other plug. follow that link.
[Modified by mr. carpenter, 3:12 AM 11/26/2002]
Old Feb 10, 2003 | 08:14 PM
4potnick's Avatar
Would this be the same if you put a 88si cluster in a 89dx.
Old Feb 11, 2003 | 08:25 AM
EF_LSVtec's Avatar
Default Re: crx si cluster swap to 89 crx dx help! (4potnick)
if its the same year, then its plug and play. I have an 88 Si cluster available if anyone wants it...$50
Old Feb 12, 2003 | 07:47 PM
Torino91LS's Avatar
My buddy owns a 89 Civic DX, it's 5 speed. He wants to use the 88-91 CRX Gauge cluster can it be done??
Old Feb 12, 2003 | 09:47 PM
-16V-'s Avatar
Default Re: crx si cluster swap to 89 crx dx help! (kincaidcrxsi)
As long as its a 88-89 si cluster it should work fine....
Old Feb 12, 2003 | 09:56 PM
Default Re: crx si cluster swap to 89 crx dx help! (1991_jdm_sleeper)
the only time wiring changes need to be made are when swapping a88-89 w/a 90-91 or vice versa.
exsinnovation
42
Oct 20, 2013 06:28 AM
todubbled1
14
Oct 30, 2010 09:23 PM
judd_123
Feb 7, 2010 04:52 PM
E46Kid
11
Jan 27, 2010 07:13 PM
CRXB18C1_ALL MOTOR
Jul 21, 2009 07:34 AM
