ZEX nitrous on ZC motor. hook up witch to TPS ? which wire..
Old Apr 20, 2001 | 05:21 PM
WickedPerform's Avatar
New User
Default ZEX nitrous on ZC motor. hook up switch to TPS ? which wire..???
I just finished installed a zex nitrous kit in an 89 hatchback with a ZC swap, then I went hook up the "spray" switch, I figured it was the Red/Blue wire. It wasnt, and it wasnt the yellow wire either and the Green wire is constant. So my question is how/where do you hook up the switch to the TPS.. Tried each wire at WOT... Cant figure it out. any suggestions ? I got it temporarly hooked up, but I dont deem it very safe.... Thanks
[Modified by WickedPerform, 6:22 PM 4/20/2001]
Old Apr 21, 2001 | 05:38 PM
elusiveracing7's Avatar
Default Re: ZEX nitrous on ZC motor. hook up switch to TPS ? which wire..??? (WickedPerform)
get a volt-meter and test which one is operating at 4volts of whatever it is
lsnidex
Mar 30, 2009 08:51 AM
aemciv
May 8, 2003 12:54 PM
SlowB16
Jul 15, 2002 09:10 PM
