Zex and explosion
Old Jul 15, 2002 | 05:14 PM
SlowB16's Avatar
Default Zex and explosion
A friend of mine just put his ZEX kit on and took it for a test run and squeezed a total of three times. First two went fine but the last one didnt go so well. Apparently a flame shot out of the intake tube, there was a burn mark near the headlight on the metal and the inside of the filter was all messed up. I looked at the plugs (which were all black and looked a bit burnt, so we ordered some colder NGK's bckpr7-11 I think) and reset the computer, so hopefully it will run fine now, but he needs to know which wire is the WOT. COuld someone help him out?? thanks
Old Jul 15, 2002 | 05:47 PM
SlowB16's Avatar
Default Re: Zex and explosion (SlowB16)
pleaaaseeeee
Old Jul 15, 2002 | 06:05 PM
CovertFI's Avatar
can you please provide pics
Old Jul 15, 2002 | 06:07 PM
SlowB16's Avatar
Default Re: Zex and explosion (CovertFI)
I dont have any or I would. But, the ZEX kit asks for a wire to be ran to the WOT wire/switch in the car. Where this wire is I have no idea..maybe on the map sensor or something?
Old Jul 15, 2002 | 07:05 PM
M.A.R.C.'s Avatar
when i had my zex kit the instructions were to wire it to the TPS signal wire which on my car (00 ex civic) i THINK was a the red/black one on the TPS plug
Old Jul 15, 2002 | 08:23 PM
wickedxboi's Avatar
Default Re: Zex and explosion (CivicRyda2k)
on a honda the tps, there are 3 wires and the the red/black wire should be the 1 in the middle that you tap.
Old Jul 15, 2002 | 08:32 PM
ion_four's Avatar
Default Re: Zex and explosion (wickedxboi)
I don't believe there's a switch on there, stock. I don't have "naaaaaaws" but I think there's a little contact switch you attach to the throttle so that it only sprays at Wide Open Throttle...
Old Jul 15, 2002 | 09:06 PM
rjardy's Avatar
Default Re: Zex and explosion (ion_four)
ZEX learns the throttle curve of your TPS, it uses the TPS as a "switch".
Rob
Old Jul 15, 2002 | 09:10 PM
M.A.R.C.'s Avatar
Default Re: Zex and explosion (rjardy)
Rob
damnit u beat me to the post
hb_usc
Jul 13, 2006 10:38 AM
aemciv
May 8, 2003 12:54 PM
pelotudo
Jun 7, 2002 11:17 PM
accord_ex90
Feb 27, 2002 12:55 PM
