Aem CAI trouble. Need suggestions.
Old Nov 24, 2002 | 04:11 AM
sparknblaze's Avatar
Default Aem CAI trouble. Need suggestions.
I installed the AEM CAI on 1995 accord wagon about 2 weeks ago. I started hearing this wierd noise last week @ idle and on take-off and thought it was coming my tranny mount but upon investigation yesterday I discovered that the pipe from the CAI was being chafed by the edges of the hole that leads to the inside of the wheel well from the engine bay. I folded a sheet of paper and put it between the pipe and edge but any suggestions on how to permanantly fix the problem? I don't know of too many flexible materials that can put up with such a rigorous task.
Old Nov 24, 2002 | 06:13 AM
Stew Pidasso's Avatar
Default Re: Aem CAI trouble. Need suggestions. (sparknblaze)
Cut a slit in a thick piece of fuel line and slip it over the sheet metal. It will rub on the hose instead. Cheap fix...
Old Nov 24, 2002 | 11:05 AM
Desslok's Avatar
Default Re: Aem CAI trouble. Need suggestions. (Stew Pidasso)
Make sure the hole is bug enough for the pipe to move and use that rubber mount that came w/ it. That way, if you have any problems, they will warranty it.
Old Nov 24, 2002 | 02:00 PM
iam7head's Avatar
Default Re: Aem CAI trouble. Need suggestions. (sp)
forget about the warranty sh-t
I cut off my old autozone slip-on wheel cover
and place it to the metal line with zap tie tighten it.
Matgallis
Feb 3, 2004 08:02 PM
majeed11
Aug 22, 2003 08:26 PM
tomn_gsr
Apr 21, 2003 09:58 AM
WhitEdRift
Apr 13, 2003 08:45 PM
99SportSedan
Jun 29, 2001 01:03 AM
