GSR vs LS Crank
Old Nov 23, 2002 | 07:59 PM
ChiBoy's Avatar
Default GSR vs LS Crank
Besides the stroke, are there any differences between the GSR and LS cranks? I know the LS stroke is a little longer, but is the VTEC crank stronger?
I’m planning a build up, and I was wondering if a little more stroke would be worth the sacrifice in R/S ratio.
FWIW, I have a GSR block that I plan to sleeve to 85mm. It will get the head from my B16, and I’m also planning to go with a JRSC at 8psi. I know there are a lot of other parts to add, but this is a question about the crank, not the whole build up.
Old Nov 23, 2002 | 08:07 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: GSR vs LS Crank (ChiBoy)
K.i.s.s
Old Nov 23, 2002 | 08:09 PM
Sonny's Avatar
You are gonna have to spin that blower extremely fast to get 8 psi on a 2 liter VTEC block.
Sonny
Old Nov 24, 2002 | 11:26 AM
boosted3g's Avatar
Default Re: GSR vs LS Crank (Sonny)
Go with the Ls crank. You can spin that plenty high ad still pull plenty of power up top. Id be more worried about he blower keeping up and keeping the intake temps from going through the roof.
Old Nov 24, 2002 | 11:43 AM
tony1's Avatar
The ls and gsr cranks are both strong. You won't have to worry about breaking either. As for which one to use, it depends how high you want to rev. The ls crank will make more torque and peak earlier but won't have the pull past 8k like the gsr crank will. It really comes down to your application and what you want out of the motor. Being supercharged, you probably don't need to rev too high so i would use the ls crank. It will have a little better powerband for a street car. The sacrifice in rod ratio isn't gonna kill you at 8krpm. If you were reving to 10k it would be a different story.
Old Nov 24, 2002 | 03:48 PM
ChiBoy's Avatar
Yes, I didn't consider that. 2L is the target, but maybe I should rethink the JRSC part.
My primary focus is autocross, not drag. I would really like to get to 230-250 to the wheels, but I want it to be usable on the autocross course. I also want to shoot for a redline around 8.5k.
Any suggestions as to which way I should research? Maybe I would be better off with a small turbo? Maybe I don’t need that much HP for autocross?
I want to make a plan before I really do anything, but now I’m not sure.
Old Nov 25, 2002 | 05:15 PM
ChiBoy's Avatar
Lil' bump for the followup.
TurboCivicR93
Aug 18, 2012 02:33 PM
teefunk01
Oct 28, 2010 04:16 AM
escape2me
Mar 23, 2005 11:03 PM
dc2_and_ef
Feb 12, 2004 04:08 PM
hybrid901
Nov 11, 2002 12:34 PM
