Help! It's getting cold and heat is not working...
Old Nov 23, 2002 | 04:51 PM
Touch's Avatar
Default Help! It's getting cold and heat is not working...
Heat in my 92 cx is not working. Fluids are fine, but I am getting a code 10 & 14 which I haven't been able to fix. Need help soon. It's cold.
thanks
Old Nov 24, 2002 | 03:03 PM
iwhichisme's Avatar
Default Re: Help! It's getting cold and heat is not working... (Touch)
code 10 is IAT sensor - intake air temp
code 14 is IAC valve - idle air control valve
Niether of these should be causing your heat not to work. I would have a look at the heater core, and make sure everything is working ok. YOu also may want to have a look at the blower to see if its doing its job, and also check the little flap door that exposes the core to the passenger compartment. hope this helps
chazz
Old Nov 24, 2002 | 03:19 PM
keebler65's Avatar
Default Re: Help! It's getting cold and heat is not working... (iwhichisme)
when you say it isnt working....does it not blow air? or does it blow, but blow cold air?
Old Nov 24, 2002 | 06:57 PM
Touch's Avatar
Default Re: Help! It's getting cold and heat is not working... (keebler65)
blows cold air
At first it's warm then its warm, then it gets cold.
[Modified by Touch, 10:58 PM 11/24/2002]
Old Nov 24, 2002 | 07:00 PM
showcarmike's Avatar
check the heat coil
Old Nov 24, 2002 | 07:07 PM
Touch's Avatar
Default Re: Help! It's getting cold and heat is not working... (showcarmike)
Where's that?
Old Nov 24, 2002 | 09:06 PM
keebler65's Avatar
its not his thermostat, is it? that just came to mind but i dont remember how it works maybe someone can back me up or correct me on that. just a thought though
Old Nov 24, 2002 | 11:01 PM
Touch's Avatar
If it was the thermostat I think that one of the return hoses would not get warm, but they do. Very cold and I gotta turn on the ac to defrost. It sucks, help you guys...
Old Nov 25, 2002 | 07:29 AM
Touch's Avatar
bump
Old Nov 25, 2002 | 09:06 AM
ITC Racer's Avatar
It is the thermostat- replace that and you should be good to go.
Old Nov 25, 2002 | 10:29 AM
racerxadam's Avatar
The way you desribe it, in order for it to be a thermostat problem the thermostat would have to be stuck open. In that case the engine temp would drop dramatically when the car starts moving. My guess is that one of the cables that opens the doors in the heater case is broken or the valve that lets hot coolant into the heater core is not opening.
Old Nov 25, 2002 | 05:55 PM
BuddhaSiR's Avatar
Default Re: Help! It's getting cold and heat is not working... (racerxadam)
play with the temperature control and have someone look to make sure that valve is opening and closing.
Old Nov 26, 2002 | 07:14 AM
Touch's Avatar
Default Re: Help! It's getting cold and heat is not working... (BuddhaSiR)
ok I'll check all those things thanks
Old Nov 26, 2002 | 05:07 PM
976's Avatar
976
New User
I have simular problem, however I DO NOT throw a code(s). My stock temp. gauge rarely works, after a long *** drive it will onyl go up 1/10 of the gauge, could I just have a faultly thermo? Please help, since were on the subject, thanks!
Old Nov 26, 2002 | 05:25 PM
Touch's Avatar
Default Re: Help! It's getting cold and heat is not working... (w00t!)
I think that is a faulty thermostat. It does that when it is stuck open.
Old Nov 26, 2002 | 05:42 PM
supercompact's Avatar
Check on the firewall where the heater hoses run in to the heater core in the engine compartment. There is a cable that opens and closes a valve for the hot water to flow into the heater core. When you move the dash selector from cold to hot you should be able to see the cable opening and closing. You will probably need a friend to move the selector while you watch the cable.
Old Nov 27, 2002 | 09:42 AM
976's Avatar
976
New User
Default Re: Help! It's getting cold and heat is not working... (supercompact)
Good info, thanks guys.
OZ36
Sep 8, 2011 05:39 PM
aust 97 coupe
Jan 3, 2009 05:21 AM
batallic
Oct 30, 2008 08:14 PM
drm109
Aug 10, 2008 04:30 PM
Canonm7
Jun 28, 2005 08:25 PM
