Loud Valve tapping!!!
Old Nov 23, 2002 | 04:19 PM
lonefuzzy79's Avatar
Default Loud Valve tapping!!!
Adjusted the valves on my car today as the valves were tapping like hell. Went .008 intake side and .009 on the exhaust side and now they are louder than before I can hear every single tappet! I am thinking then I going tighter on the clearances like .006 intake and .008 exhaust. Thoughts, it is quite loud. Anyother thoughts?
Old Nov 23, 2002 | 04:22 PM
AB16A2T's Avatar
Default Re: Loud Valve tapping!!! (lonefuzzy79)
The proper specs for valve adjustments should be on the inside of the hood of your car.
Old Nov 23, 2002 | 04:29 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Loud Valve tapping!!! (AresB18C1Turbo)
Just do it over again and make sure your engine is "cold to the touch"...as in, sitting over night-cold
Old Nov 23, 2002 | 05:21 PM
JDMH22HATCH's Avatar
Do .007 intake and .008 exhaust. And make sure the rocker arm bolts are torqued down because when one comes loose it makes a ton of noise. When you are done, take a flathead screwdriver and place the tip on the valvecover and put your ear to the handle. Go from place to place over your valves and you will be able to see which ones have problems, if any. Just remember, humming is normal, but a tapping or knocking noise isn't. Hope this helps and good luck.
Old Nov 23, 2002 | 05:33 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Loud Valve tapping!!! (JDMH22HATCH)
Valve specs for a B18C1 are .006-.007 Intake and .007-.008 Exhaust. If you have a B18C1, you are off. Prolly the reason for the tapping.
HTH
[Modified by Archidictus, 9:33 PM 11/23/2002]
Jax4gencivic
Jan 17, 2023 06:41 PM
d17beast
Honda Civic (2001 - 2005)
Nov 12, 2010 03:12 PM
D3vin
Aug 29, 2010 01:26 AM
spriddle
Dec 16, 2008 04:02 AM
b20integrapower
Jan 29, 2006 08:31 PM
